    Tallest tires option?
    Abitibi
    Abitibi
    Number of posts : 479
    Tallest tires option? Empty Tallest tires option?
    Post by Abitibi Thu Nov 05, 2015 8:37 am
    G'morning gents
    I'm looking to confirm what would be the tallest tire that could fit under our vans. I'm not going for the slick city look but the other ways, rough and tough.
    I'll be using my van on forestry roads as much if not more than paved road and will likely dress her up with all terrain LT tires.
    Not many options so I'll move up to the 15" rims. I'm not looking for fat ones, I'm more into the skinny type anyway Wink
    I haven't seen many with that style of tires so hard to get any info. Since I'm getting new rims as well, if there's options with backspacing that can also help with taller tire fitment I'm listening!
    Or fitting an extra leaf? Moving the axle rearward? As long as it still looks close to stock I'm good.
    Cheers
    Mr. D
    Tallest tires option? Empty Re: Tallest tires option?
    Post by Twinpilot001 Thu Nov 05, 2015 12:23 pm
    likely 235 x 75 15's maybe 1 size larger?? Maybe???????????????
    Abitibi
    Abitibi
    Post by Abitibi Thu Nov 05, 2015 5:04 pm
    Those would be about 29" tall. Lots of choice in that size but do you really think they would fit? That would be quite the jump from my current 25" or so!
    Number of posts : 1422
    Post by Magic Bus Thu Nov 05, 2015 5:57 pm
    That's gonna be  at least a minor challenge but if you stay with a narrow tread getting tall should work for you.  The clearance issue is always when you stick a wider rim with an offset that makes it stick out further.  Then the problem of rubbing the rear fender comes into play.   A 15x6 or 15x 7 rim with a zero or positive offset with a 225/75 or maybe even up to a 245/75 might fit.
    At least you won't likely have to raise it with springs/air shocks, blocks etc..
    Most tires don't come taller than the 75 ratio though so you'll kind of have to do some math.
    Here is a link to a calculator
    https://www.tacomaworld.com/tirecalc
    Keep in mind...
    245 = 245mm tread width
    75= 75% of tread width at sidewall
    15= rim diameter
    If you get it dialed in and mounted up take some pix for us.
      Current date/time is Sun May 19, 2024 6:46 pm
