    4 speed ever an option
    Number of posts : 512
    4 speed ever an option Empty 4 speed ever an option
    Post by pan58head Sat Sep 18, 2010 9:19 pm
    quick question, was a 4 speed ever an option for the 1st or second 2nd generation? If not any body figure out a shifter set up Thanks Bob
    4 speed ever an option Empty Re: 4 speed ever an option
    Post by donivan65 Sat Sep 18, 2010 9:29 pm
    I have a 4 speed trans,,,,,just sold the shifter column,,,,,they came on 2nd Gens,,,,,,,double H pattern on the tree,,,,,,,,Reverse used a cable to the 3rd lever on the trans,,,,,,there were some for sale in our parts section,,,,,,,,
    4 speed ever an option 4spd10
    Post by donivan65 Sat Sep 18, 2010 9:32 pm
    4 speed ever an option 4_spee10
    Number of posts : 1778
    Post by m1dadio Sun Sep 19, 2010 6:09 pm
    Man that four speed shifter is a real rare item
    M1D
    Post by pan58head Sun Sep 19, 2010 9:57 pm
    cool, Anybody figured out a shifter that will work with a nornal 4 speed. My handi needs to be a standard again Bob
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Tue Sep 21, 2010 10:13 am
    Don, was the 4 speed in the 2nd gen vans a truck style granny low 1st? Or was it a normal 1st gear like the cars have?
    Post by donivan65 Tue Sep 21, 2010 11:15 am
    Well 4th gear is direct drive just like every transmission ever built so the other speeds are geared lower,,,,,,and that would make 1st gear a Granny Gear Stump pulling speed ,,,,, not to be confused with an Overdrive transmission that changes high gear into a speed that is more than 1 to 1 direct drive to something like 3/4 to 1,,,,,,,, Do you still have yours for sale, Joe?
    kookykrispy
    kookykrispy
    Post by kookykrispy Tue Sep 21, 2010 11:56 am
    Don, I'm thinking I might end up using it, so its not for sale at this time.
    Since I swapped to tall 275/60 rear tires, I'm thinking a 4 speed with a lower 1st gear would be nice... but I don't want a useless granny low first gear like in the SM465. I need to do a little more research on this trans, or maybe just swap it into my van and see how it does?
    How does the shifter come apart from the column? I can't figure that one out... seems to be stuck to the column near the top somehow
    Post by donivan65 Tue Sep 21, 2010 3:13 pm
    Well,,,,,,,did you pull the shift lever out,,,,,,,,it also holds the shaft into the column,,,,,,
    kookykrispy
    kookykrispy
    Post by kookykrispy Wed Sep 22, 2010 9:27 am
    Oh cool... no I didn't know that
    Post by pan58head Tue Oct 05, 2010 10:12 am
    We'll I scored a 4 speed tail shaft housing, all I need now is to find a column , I have found a half a dozen van s for parts but no 4 speeds Bob
    Number of posts : 946
    Post by BvrWally Tue Oct 05, 2010 10:47 am
    They are out there, but as said previously...very rare! I myself, have only seen one and that was in a 108 that had been used as a funeral delivery hauler and was black and here in Ohio! In 36 years, just one!
    B.W. Smile
    Post by Guest Tue Oct 05, 2010 5:48 pm
    Rollie - There is a rusted 1968 Chevy 108 panel in Mentor, Ohio with a 4-speed on the column. Homeowners won't sell van. I think it must be sentimental to them. I met the van owner back in 1986 and perhaps the guy died since then and the family is keeping the van. What a shame, the parts could help other vans survive. Maybe it's time to knock on the door again.
      Current date/time is Wed May 08, 2024 3:13 am
