    Rear brake hose length ?
    rustytoolss
    rustytoolss
    Number of posts : 624
    Rear brake hose length ? Empty Rear brake hose length ?
    Post by rustytoolss Wed Oct 21, 2015 8:17 pm
    Why are there so many rear brake hose lengths for our A's ?
    Napa list these lengths 20.25" / 17.5" / 15.75"
    Rock Auto list 16.0" / 18.5"
    I've even found a listing for right and left REAR brake hoses. Did the trucks ever have a right and left REAR brake hoses ?
    My rig is a 64 pickup. I have not measured mine yet. But was gathering parts. What is the correct length for the center rear hose ??
    Rear brake hose length ? Empty Re: Rear brake hose length ?
    Post by donivan65 Wed Oct 21, 2015 8:25 pm
    ,,,,on our Chevys,,,,,,,we put on braided hoses instead of the rubber ones when we want to show off,,,,, they come in all sizes,,,,,with standard aircraft fittings on them and you add the adapter fitting to connect it to your system,,,,,,
    Rear brake hose length ? 2nd_ge12
    busman78
    busman78
    Number of posts : 483
    Post by busman78 Thu Oct 22, 2015 6:38 am
    Jack the rear up so the suspension is at max travel. measure the distance from the line fitting to the rear axle fitting with a little extra added in, better to error long than short.
    Number of posts : 8732
    Post by dix Thu Oct 22, 2015 10:18 am
    the full sized dodge pick up trucks were also referred as a100
    rustytoolss
    rustytoolss
    Post by rustytoolss Thu Oct 22, 2015 11:29 am
    dix wrote: the full sized dodge pick up trucks were also referred as a100
    did not know that!
    Post by dix Thu Oct 22, 2015 3:14 pm
    most of the time they were d100's
    but over the years confusion set in, this is why you will
    see parts for the a100 and you know that won't fit or work,
    https://www.google.com/search?q=dodge+100+pickup&rlz=1C1PRFC_enUS618US618&espv=2&biw=1120&bih=578&tbm=isch&tbo=u&source=univ&sa=X&ved=0CDMQ7AlqFQoTCNrvhLaN18gCFQjzPgodFBwLgg
      Current date/time is Sun May 19, 2024 9:35 am
