I can't remember how to run the wires! Been too long since I took it all apart!
The wiring diagram in the G10 service manual only shows a motor with only two terminals. A 1-speed motor with only two terminals (no washer). My motor has 4 terminals on the wiper motor. There are three terminals with one more a bit away from them to the left.
The manual shows a light blue wire going from the switch to the motor. That motor terminal is a double, with a yellow wire going to the fusebox. I did mark the wires that go to the wiper motor. I have that double light blue & yellow connector. But I have two more single connectors, one black, one yellow. The yellow one is real short and goes to another double connector that I'm sure goes to the washer unit. I assume the yellow one would go on that terminal that is by itself, but what order do the other three go on those three terminals?
My switch is a 2-speed with washer button, 3 terminals on the back of the switch. I think I have the switch right. one single connector light blue plugs into a terminal spaced a bit away from the other two terminals. That light blue wire definitely goes to the double terminal on the motor. The switches other two terminals are at a right angle to each other. I put a double connector onto those that has a dark blue and a black wire.
Thanks!
Thanks!
