rustytoolss
Variable speed wiper motor park timing?
Does anyone have any helpful information about how to adjust the park timing on a variable speed wiper motor. The service manual that I have does not say all that much. My motor is parking 180* off.
- Number of posts : 8726
not a clue
- Number of posts : 12218
If you say they park straight up, that would make them 90 degrees off,,,,,,,,Park is a set of contact points or a solenoid that keeps the motor turning when you turn off the switch until a cam opens the points and the motor stops when the wipers get parked,,,,,,can you remove a cover to see something like that on the motor? Did it ever work?
https://www.google.com/?gws_rd=ssl#q=adjust+dodge+wiper+park+position
donivan65 wrote:If you say they park straight up, that would make them 90 degrees off,,,,,,,,Park is a set of contact points or a solenoid that keeps the motor turning when you turn off the switch until a cam opens the points and the motor stops when the wipers get parked,,,,,,can you remove a cover to see something like that on the motor? Did it ever work?
I guess you might be right about the 90* . I don't know if they ever worked. I bought this pickup last fall from CALIF. This is the first I've worked with it.
Anything could be wrong,,,,,,the linkage,,,,the motor,,,,,,so if you removed the wipers arms and put them where they belonged,,,,,with that motor in its parked position,,,,what happens,,,do the wipers then wipe the headlights and bumper? or undo the linkage at the motor and see what the linkage needs to be doing to wipe then park as compared to what the motor is doing,,,,,,,,,,,the motor goes round and round to make the wipers go up and back,,,,,,,maybe an arm is in the wrong place
donivan65 wrote:Anything could be wrong,,,,,,the linkage,,,,the motor,,,,,,so if you removed the wipers arms and put them where they belonged,,,,,with that motor in its parked position,,,,what happens,,,do the wipers then wipe the headlights and bumper? or undo the linkage at the motor and see what the linkage needs to be doing to wipe then park as compared to what the motor is doing,,,,,,,,,,,the motor goes round and round to make the wipers go up and back,,,,,,,maybe an arm is in the wrong place
When I put the wipers at the bottom of windshield (parked), then turn them on. They went down toward headlights.
diamond dave- Number of posts : 565
I would disconnect the arms from the motor, then run the motor and let it come to a stop. then reconnect the arms at the motor. then try it again. i'm not far from you, in canal fulton. so if you need any help, let me know.
can you turn the motor 180 degrees ?? can you take a photo of the motor and it's location ???
diamond dave wrote:I would disconnect the arms from the motor, then run the motor and let it come to a stop. then reconnect the arms at the motor. then try it again. i'm not far from you, in canal fulton. so if you need any help, let me know.
thanks, I'll try that.
dix wrote:can you turn the motor 180 degrees ?? can you take a photo of the motor and it's location ???
cant reposition the motor 180* I've never posted pictures. Is it hard to do ?
pm sent
tdc- Number of posts : 32
Registration date : 2014-03-10
did you ever figure this out, rustytoolss?
Not yet, I did some searching on the web and found a picture of the wiper system of an A100 with variable speed wiper. The photo was from the actual dodge parts book.
In the parts book photo (in the parked position) the passenger side inner pivot arm was in an up type position...mine is down ????
If you were to look up under your dash (passenger side) at the arm that goes into the pivot. Is in a up position ? or a down position ? I you could look under your dash, at least it may help .
Scottie told me that both of the long link arms are the same length.
just a suggestion?? remove the outside wiper arms- then cycle the wiper motor & turn it off! let it park itself!! then reinstall the arms.
I'll go snap some pictures for you. I can already tell by looking at your wiper arm photo that something's wrong, the wiper motor's going to push that arm, which is going to send your blades down rather than up. Be right back with some photos.
Passenger side:
Driver side:
Wiper motor:
It would appear that the cam at your motor is on 180° from where it should be. I'd pull the wiper blade arms off, flip the cam on the motor, let the thing park itself again and verify the inside wiper arms are positioned like in my photos. Then reinstall the wiper blade arms at the bottom of the windshields and you should be good.
Driver side:
Wiper motor:
Also, taking these photos has made me aware I am missing a bolt from my driver side wiper assembly.
I've done that. They will always end up in the vertical position when parked.
tdc wrote:Passenger side:
Driver side:
Wiper motor:
I will give that a try in the morning. Thanks for the photos. By the way is your sytem a 2 speed or variable ??
Something's on backwards, and it's gotta be at the wiper motor. Look at the linkages in my photo, then compare them to your photo, my pushrods start out extended away from the motor, yours start out overlapping in front of the motor. You've gotta rearrange something there so that they are resting out away from the motor. This will make your inner wiper arms pointed away from the motor and towards the sides of the van, like in my photos, rather than pointed in and towards the wiper motor.
It's varible.
Driver side:
Wiper motor:
When you say flip the cam do you mean the internal gear in the wiper transmission ? OR the link arm on the back of the motor ?
tdc wrote:Something's on backwards, and it's gotta be at the wiper motor. Look at the linkages in my photo, then compare them to your photo, my pushrods start out extended away from the motor, yours start out overlapping in front of the motor. You've gotta rearrange something there so that they are resting out away from the motor. This will make your inner wiper arms pointed away from the motor and towards the sides of the van, like in my photos, rather than pointed in and towards the wiper motor.
Is your wiper motor (the round can part "motor" ) hanging toward the drivers side ? Mine is. Hard to tell from your photos>
