busman78
Vantucky
    Removing front Doghouse panel
    Vantucky
    Vantucky
    Number of posts : 112
    Registration date : 2015-05-14
    Removing front Doghouse panel Empty Removing front Doghouse panel
    Post by Vantucky Tue Sep 29, 2015 9:33 am
    Hey all,
    Trying to remove my doghouse to clean the van and do some floor repairs.
    I've got the other 4 doghouse panels out of the way and the front panel just wants to stick around.
    I was looking through the service manual and it pointed that the bolts on the floor were all that is holding it in, but it looks like it is tacked to the shroud around the radiator? Is this normal or did someone really do something really weird? maybe to reduce vibration or something.
    So to remove the shroud some of the engine wiring will have to be undone and it will have to be unbolted from the radiator, and the bolts look pretty unreachable without the front doghouse panel out of the way. What the heck? Am i just really not seeing something?
    Frustrated... Mad
    busman78
    busman78
    Number of posts : 483
    Removing front Doghouse panel Empty Re: Removing front Doghouse panel
    Post by busman78 Tue Sep 29, 2015 7:14 pm
    Emergency brake bracket need to be unbolted there are two bolts to the doghouse, there are a couple bolts attaching the lower right and left splash panels to the radiator mounting frame, the harness is held by two plastic straps, I pulled the radiator before removing the front panel, it comes out the bottom, but I suspect you can drain, remove the hoses and take the radiator out with the front panel from the top. Hope I got it all, it has been a couple years and I was stripping the doghouse off for a /6 to V8 conversion so really did not pay much attention.
    Vantucky
    Vantucky
    Post by Vantucky Thu Oct 01, 2015 9:12 am
    busman78- I already have the emergency brake bracket undone as well as the 4 splash panel bolts;those made my radiator loose...
    It appears that splash panel is spot welded to the shroud and to the front doghouse. My question is, is this normal or is this weird?
    I was browsing through some pictures of other peoples doghouses- RodStRace had some good pics of his, it didn't have any of the shroud pieces attached.
    I also kind of want to avoid undoing the throttle linkage and the wiring harness for now... Maybe i will try and get a picture up tomorrow.
    busman78
    busman78
    Post by busman78 Thu Oct 01, 2015 9:31 am
    Normal is the lower splash guards are welded to the frame in a couple spots but not to the radiator frame. Not sure if the shift linkage, accelerator cable and EM cable pass through the radiator frame for mine is now modified (FSR Tug Radiator) and the left splash guard all but gone in order to fit a later model Mopar Aluminum master cyclinder and proportioning valve.
    whalemstr
    whalemstr
    Number of posts : 248
    Post by whalemstr Thu Oct 01, 2015 9:34 am
    This is what the one I have in my pile of stuff looks like...
    Removing front Doghouse panel Front%20doghouse%20panel%202_zpsm0hrni3f
    Removing front Doghouse panel Front%20doghouse%20panel%201_zps4xd7b1z6
    Removing front Doghouse panel Front%20doghouse%20panel%203_zpshqzwosqi
    hope this helps...
    dan
    Number of posts : 1135
    Post by benwah Fri Oct 02, 2015 7:56 am
    Look at the bottom of the last picture there is a bracket that it bolts to. Drop the belly pan to get a better view and to remove the bottom bolts. Good luck.
    Vantucky
    Vantucky
    Post by Vantucky Mon Dec 07, 2015 9:23 pm
    Turns out:
    Disconnect 3 splash plans.
    Disconnect radiator shroud, 4 bolts.
    Prop up radiator
    Remove a couple more bolts.
    Remove wiring harness at back of engine.
    Remove throttle linkage.
    Cuss a little and the bastard is off.
    Cheers
    Dingeldeins
    Dingeldeins
    Number of posts : 20
    Registration date : 2013-02-19
    Post by Dingeldeins Tue Dec 08, 2015 3:28 am
    Hi !
    Has anybody an idea, where I can get the clambs that hold the doghouse-Panels to the ground?
    There are at least two for each side an two or four for the back!
    Question Question Question
    Number of posts : 3046
    Post by RodStRace Tue Dec 08, 2015 11:18 am
    Extruded "U" nuts
    Au-ve-co brand part # equals a box of 25
    1/4"-20 10050
    5/16"-18 10053
    3/8"-1610055
    busman78
    busman78
    Post by busman78 Tue Dec 08, 2015 12:26 pm
    www.clipsandfasteners.com
    They have the cage nuts and the correct washer bolts
    Dingeldeins
    Dingeldeins
    Post by Dingeldeins Tue Dec 08, 2015 1:13 pm
    Thanks guys,
    checked them both!
    Clipsandfasteners has an eBay-shop and offers international shipping!
    santa
      Current date/time is Tue May 07, 2024 3:31 pm
