    Removing Switches from Dash Panel?
    wacko
    wacko
    Number of posts : 423
    Removing Switches from Dash Panel? Empty Removing Switches from Dash Panel?
    Post by wacko Thu Jan 07, 2010 11:34 am
    Hello Everyone,
    Can someone tell me the proper procedure to remove the Ignition Switch, Wiper Switch, and Light Switch from the dash panel. I just don't want to break anything.
    Removing Switches from Dash Panel? Empty Re: Removing Switches from Dash Panel?
    Post by G-Man Thu Jan 07, 2010 1:04 pm
    there a button on the back of the light switch you push when you have the rod pulled out and on the Ign switch use a paper clip in the little hole by where the key inserts push in the paper clip as you turn the key as you push in the paper clip and the key ign lock comes out then the Ign bezel will come out easly. Maybe Don has some picture of this
    Post by donivan65 Thu Jan 07, 2010 1:23 pm
    Sometimes the bezel comes off over the cylinder,,,,,sometimes you need to put the key in,,,,put a paper clip in the hole,,,push it in while turning the key counterclockwise,,,,There is a spring you push on the back of the headlight switch that lets the knob and shaft come out,,,,,and that spring might not be happy to be pushed,,,,you can wear out your finger pressing it and pulling and pushing on the knob until it finally comes out,,,,if there is not a set screw in the wiper knob,,,,pull it off,,,,
    Removing Switches from Dash Panel? Repair29
    wacko
    wacko
    Post by wacko Fri Jan 08, 2010 9:47 am
    Perfect. thanks Guys. I did not need to use a paperclip with the ingnition.
      Current date/time is Sun May 19, 2024 10:44 am
