I've been reading different things about the engine paint for the Ford eVans. I believe I have the 170 on my 62 Falcon, but i could be totally wrong!
I'm changing the valve cover gasket (going with cork...is that better or worse than the rubber?, it what they had in stock). I thought since I'm pulling the valve cover off I might as well repaint it as well, as the paint is looking rather ragged & flaking in places.
What color paint should I use? I have an Orange paint, but read that the Fords used Blue, but read in other places that the Orange is used for an engine size thats NOT the 170... just thought i'd consult the pros before doing anything
You guys rock
thank you. Can someone confirm that this is indeed a 170 for me? and what transaxle is this? (i do not know how to decode the stamp)
You guys rock
