    brake line & engine harness routing
    jdlaugh
    jdlaugh
    Number of posts : 298
    brake line & engine harness routing Empty brake line & engine harness routing
    Post by jdlaugh Mon Mar 30, 2015 4:33 pm
    Anyone have pictures of the routing for the front brake line to the passenger wheel and the engine harness back to the alternator and starter solenoid after it passes through the floor? It seems like there should be hangers to hold the brake line and harness in place, but I took things apart a couple years ago and not sure where they mount and the exact route from one side to another.
    I kick myself for not taking pictures before I started tearing everything out... Rolling Eyes
    Number of posts : 2086
    brake line & engine harness routing Empty Re: brake line & engine harness routing
    Post by Seth G Mon Mar 30, 2015 7:31 pm
    I'm glad you asked this, I'm in the same boat
    Number of posts : 1747
    Post by econopoor Mon Mar 30, 2015 7:34 pm
    I can get you some pictures tomorrow if you can wait.
    jdlaugh
    jdlaugh
    Post by jdlaugh Mon Mar 30, 2015 8:02 pm
    Tomorrow would be great. Any help would be better than flying blind! Very Happy
    jdlaugh
    jdlaugh
    Post by jdlaugh Tue Mar 31, 2015 12:32 pm
    Found this image posted by Old Skool while searching around. Looks like longer bolts to hold down the front of the doghouse, with nuts screwed on below to hold harness hangers. I don't see the passenger brake line in the photo, but I'm guessing it would also run along in front of the doghouse opening.
    brake line & engine harness routing 100_1210
    Post by econopoor Tue Mar 31, 2015 6:38 pm
    Old Skools stuff looks much better than my rusty junk. The right front brake line runs across the bottom of the floorboard over to the right frame rail. Straight back through bulkhead that you see the wires and heater hoses running through. It turns and drops below the frame to the hose connector. It is secured to the floorboard with clamps on the bolts that hold the throttle shaft. It appears Vic has his brake light wiring harness is already bolted to the studs. You can just see a clamp his picture. I took some pictures of the two trucks I have at my disposal today but both have had the brake lines replaced and not routed back where they should have been. Not much use to us here. Hope this helps. Let me know If I can do anything else. I'll see if any of my trucks in my barn still have original routing.
    jdlaugh
    jdlaugh
    Post by jdlaugh Wed Apr 01, 2015 6:34 am
    Thanks for trying. Since the harness and passenger side line run the same route across the floor, I mounted them together using padded clamps attached to the doghouse bolts.
    Post by Seth G Wed Apr 01, 2015 10:41 pm
    There's got to be a better pic than that out there. Straight stock. I may have my line but It's probably folded up...
    It's funny, on jobs I always take tons of pics to CMA, but I don't have a one of this. lol
    Number of posts : 809
    Post by Bruce67Econoline Thu Apr 02, 2015 4:00 pm
    I hope this helps, it is still original , the one thing I did notice is missing is an oval plastic bushing where the harness, and brake lines go through the frame . I hope these load right.
    brake line & engine harness routing Img_2813
    brake line & engine harness routing Img_2814
    brake line & engine harness routing Img_2815
    brake line & engine harness routing Img_2816
    brake line & engine harness routing Img_2817
    brake line & engine harness routing Img_2818
    brake line & engine harness routing Img_2820
    brake line & engine harness routing Img_2821
    brake line & engine harness routing Img_2822
    Post by Seth G Thu Apr 02, 2015 6:51 pm
    Thanks Bruce!
      Current date/time is Sun Apr 28, 2024 10:32 am
