I have acquired a four on the tree shifter and rods with the hope of installing a three speed with overdrive. I don't really know how the shift rods are arranged as the third shift rod I assume would go into the leftmost of the three holes on the shift rod bracket below the rad. But that is where my e brake cable currently runs... a direct path through the pulley on the bottom of the ebrake handle, through the leftmost hole, through the hole on the crossmember, and then to the yoke at the rear of the vehicle. How does the ebrake cable and shift rod use the same hole? Or does the shift rod use the hole on the upper right of the bracket? Does the Dagenham setup have a different parking brake arrangement. I have a Dagenham I am interested in selling if you need a spare. Shift rod and ebrake cable removed in image. Image is not of my van but of the van the four speed came out of.
Thank for the reply
Joel
Thank for the reply
Joel
