I've got a 1967 Econoline window van and I'm pulling the windows for paint and body. Does anyone have any leads on the 'right' rubber for these windows? Will I be forced to use universal rubber. I know corners will eventually pull away from the glass and I'd like to avoid that if possible.
1967 Econoline window van. Rubber seals
Wandervan- Number of posts : 8
Registration date : 2015-01-20
A member here EconoUSAparts ( Tim Brogan)has them. Good fit. From what I can recall the inner body gasket is not available. I believe you can use a Chevy Astro side door seal for it. I'm not sure what year is correct. Maybe Tim can steer you right.
