diamond dave
dougtappan
    rewiring the van
    dougtappan
    dougtappan
    Number of posts : 310
    rewiring the van Empty rewiring the van
    Post by dougtappan Mon Mar 02, 2015 1:02 pm
    My research shows all of the rewiring kits Painless,Centech or Rebel all have to splice into the original destinations. I have a 67 short van. My question is will the work required to rewire the van be worth it seeing as I will be using the last few inches of the original system anyway?I have fuses in my system now.Thanks in advance guys(or girls).
    diamond dave
    diamond dave
    Number of posts : 565
    rewiring the van Empty Re: rewiring the van
    Post by diamond dave Mon Mar 02, 2015 5:15 pm
    not sure about centech or rebel. but ive wired with painless, and I sell ez wire kits. never had to use the original harnesses in them. or pieces. the only thing that they all have in common with the vans is the possibility of having to extend the rear section, due to the cab forward design.
    what are you reffering to when you say splicing into original destinations?
    the ez wire kits go right to the back of the gauges, right to the engine, come with new headlight plugs, and go to all sending units.
    the only thing you would keep would be the wires going into the turn signal switch and the tail light plugs.
    Number of posts : 1778
    Post by m1dadio Mon Mar 02, 2015 5:35 pm
    I know what you mean. My wiring dosn't look too bad. needs a repair here or there, rusty fuse block. I am going to just add a new fuse box and make a couple repairs to the exsisting wiring and re tape it all. I think I have one or two light sockets that need attension. I'm not going to spend on a complete new harness that dosn't fit anyway and needs a bunch of splicing anyway to make it fit. It just dosn't seem to make sence to do that.
    m1D
    hywaychild
    hywaychild
    Number of posts : 389
    Registration date : 2008-05-27
    Post by hywaychild Wed Mar 04, 2015 12:06 pm
    I sure hope it's worth it .my factory harness was burnt pretty good so i picked up a ez harness was hoping to have it in by now but other things have slowed me down ...with a bit of luck i will have it in time for natz ?????????
    diamond dave
    diamond dave
    Post by diamond dave Wed Mar 04, 2015 6:15 pm
    hywaychild, if you have any problems with your install, give me a call. I shoulg be able to help. 330=612=4338
    hywaychild
    hywaychild
    Post by hywaychild Wed Mar 04, 2015 7:23 pm
    I've don't just about everything you can do building vans but that wiring harness scares the shit out of me .. still shooting for nat'z maybe
    Post by m1dadio Wed Mar 04, 2015 9:58 pm
    Hywaychild: One wire at a time, its easy, when you go to power it up have all switches off and all relays and fuses out . Conect battery, then add one fuse or relay at a time and check that circuit before adding another . Power it up one circuit at a time.
    hywaychild
    hywaychild
    Post by hywaychild Thu Mar 05, 2015 8:46 am
    well if i'm ever able to get back into my shop again i'm going to give it one hell of a shot
    rewiring the van Storm311
    Vanadian
    Vanadian
    Number of posts : 187
    Registration date : 2010-11-17
    Post by Vanadian Sun Jun 07, 2015 1:22 pm
    Can someone post a first gen wiring diagram, thought i had one but can't seem to find it.
    Post by donivan65 Sun Jun 07, 2015 1:32 pm
    click on them
    rewiring the van 1st_ge10
    rewiring the van 1st_ge11
    rewiring the van 1st_wi10
    Vanadian
    Vanadian
    Post by Vanadian Sun Jun 07, 2015 4:32 pm
    Thanks Don, This guy cut every wire, I'm surprised so much works with the minimal rewiring he did.
    Post by donivan65 Sun Jun 07, 2015 5:04 pm
    just start at the positive battery cable on the starter solenoid,,,,,,,hook up a 14 gauge fusible link to a 10 gauge wire,,,,,,,connect it to a screw on the horn relay,,,,,then run another from there to the dash to feed the headlights, fuse box and ignition switch,,,,,,hook another 10 gauge from the alternator output also to a screw on the horn relay,,,,,,,that upgrades the main feed system on the van,,,,,then you work on the other systems,,,,,one wire at a time,,,,,,
    Vanadian
    Vanadian
    Post by Vanadian Mon Jun 08, 2015 4:09 pm
    Thanks that's a great start! Can you tel me what each one of these are?
    rewiring the van 20150610
    Post by donivan65 Mon Jun 08, 2015 5:30 pm
    They go exactly where the guy that put them in there wanted them to go,,,,,,,,
    is the original fusebox and its 9 wires still there,,,,,,,and is there any added on electrical equipment like fog lights, back up lights, radiator fan, radio amp, wiper delay,extra cigarette lighter sockets,,,,,,,,,,,,dome lights or fans on the van,,,,,,,,
    Post by Digz Mon Jun 08, 2015 5:55 pm
    I'm going to take a stab at it for fun. #1 is a relocated Horn relay, #2 is a basic junction block, #3 is a condenser to control radio static and what the heck #4 is I have no idea.
    Vanadian
    Vanadian
    Post by Vanadian Wed Jun 10, 2015 12:49 pm
    and here I thought that was original wiring... should have known better.
      Current date/time is Thu May 02, 2024 9:15 am
