    backup light stays on
    Number of posts : 359
    Registration date : 2014-09-26
    backup light stays on  Empty backup light stays on
    Post by rocky69rhodes Sat Feb 07, 2015 6:32 pm
    whenever the headlights are on
    kookykrispy
    kookykrispy
    Number of posts : 1533
    backup light stays on  Empty Re: backup light stays on
    Post by kookykrispy Sat Feb 07, 2015 7:11 pm
    get the wiring diagram and start checking wires to find out where the wires are crossed and shorting together.
    Post by rocky69rhodes Sat Feb 07, 2015 7:11 pm
    thanks is it also possible the switch is bad or stuck
    Post by donivan65 Sat Feb 07, 2015 10:02 pm
    pull the back up light fuse out and see what happens,,,,,,,do the tail lights work or do they come on when you put the van into reverse which would mean the tail/back up wires are switched ,,,, add a test ground wire to the tail light housings and see if that puts out the back up lights when the tail lights are on,,,,,,,,,,,
    Post by rocky69rhodes Sat Feb 07, 2015 10:06 pm
    thanks Donivan
    Post by donivan65 Sat Feb 07, 2015 10:44 pm
    If you say that the back up lights come on with the headlights,,,,,,take the bulbs out of the tail lights and see if the back up lights go out,,,,,
    kookykrispy
    kookykrispy
    Post by kookykrispy Sun Feb 08, 2015 6:57 am
    It is possible that when your recent electrical short occurred that it melted the insulation and is causing the wires for backup lights and tail lights to touch now.
    https://vintage-vans.forumotion.com/t46553-something-wrong
    Pull out the wiring harness that runs along the top inner driver's side ceiling and perform a careful visual inspection. I'll bet you find your short somewhere in there. Replace/repair damaged wiring as necessary according to the 2nd gen diagram: https://sites.google.com/site/vcvcvanaticmap/colorizied-wiring-for-a-2nd-gen-chevy-van
    RIP Carl aka "viewmaster"
    Number of posts : 809
    Post by Bruce67Econoline Sun Feb 08, 2015 7:04 am
    Yet another reason this is such an amazing resource. Bravo Kooky!!!!!!! cheers cheers cheers cheers cheers
    Number of posts : 1293
    Post by Lazarusvan Sun Feb 08, 2015 8:06 am
    kookykrispy wrote:It is possible that when your recent electrical short occurred that it melted the insulation and is causing the wires for backup lights and tail lights to touch now.
    KK, I concur with Bruce. this is the most humble humble, helpful site I've ever been on. Any chance you can post up the wiring diagram for first generation Chevy?I want to make sure mine is wired properly, which it's not currently, when we redo it this week. Thanks!)
    Post by rocky69rhodes Sun Feb 08, 2015 11:19 am
    no the problem is pre smokey dashboard I will do all suggested things I did notice 2 capped off wires at the site of the dome light
    kookykrispy
    kookykrispy
    Post by kookykrispy Sun Feb 08, 2015 5:08 pm
    1st gen wiring diagram:
    https://vintage-vans.forumotion.com/t25630-first-gen-wiring-diagram
      Current date/time is Tue May 07, 2024 6:02 am
