something wrong
Number of posts : 359
Registration date : 2014-09-26
something wrong
Post by rocky69rhodes on Fri Feb 06, 2015 10:35 am
I touched a wire from the overhead dome light to the metal an now I have no power smoke came out of the dashboard
Re: something wrong
Post by rocky69rhodes on Fri Feb 06, 2015 11:10 am
wiring to starter burnt
Re: something wrong
Post by Big W on Fri Feb 06, 2015 11:20 am
Rocky!!!...you're suppose to keep the smoke INSIDE the wire. Once it gets out it's real tough to get it back in... lol! . All joking aside, that's a bummer. Maybe the old fuse holder has some burnt fuses, or did you actually burn up some wires under the dash?
Re: something wrong
Post by rocky69rhodes on Fri Feb 06, 2015 11:41 am
leave the jokes to twin pilot lol I hope its just at the starter fuses look fine tow truck on the way
Number of posts : 809
Re: something wrong
Post by Bruce67Econoline on Fri Feb 06, 2015 12:28 pm
Hopefully just minor damage, and not a major fire like I had. Good luck with the repairs.
Number of posts : 11569
Re: something wrong
Post by donivan65 on Fri Feb 06, 2015 12:36 pm
that small wire on the positive battery cable on the starter solenoid is a fusible link,,,,,,made to burn out before the van catches on fire,,,,,,,,,when something goes wrong,,,,,,its a 16 gauge,,,,,,,
Number of posts : 1412
Re: something wrong
Post by Vantasia on Fri Feb 06, 2015 12:54 pm
Shorting the dome light power wire should have blown a fuse...they work off the headlight switch. Get a diagram and trace and check all your circuits the best you can with a meter and make sure everything is fuse. PO's often bypass these safeguards over the years to get things to work.
kookykrispy
Number of posts : 1453
Re: something wrong
Post by kookykrispy on Fri Feb 06, 2015 9:51 pm
2nd gens have a fusible link between the battery and the rest of the van. 1st gens don't have that.
ditdater
Number of posts : 590
almost same deal here
Post by ditdater on Sun Feb 08, 2015 1:21 pm
evidently , my orig. dome were sw/out for the rectangle ones w/ push button on/off , as it went bad and I went to replace w/ same I also touched orange or white wite to metal and that wire wire started to melt the touching end ,but caught it in time that was all , just melted end of wire . also I noticed my headlite sw/ where you turn all the will turn on /off domes wasn't effecting my domes as they are operated by push but. on lite itself.workking fine though
Re: something wrong
Post by rocky69rhodes on Sun Feb 08, 2015 3:39 pm
ditdater wrote:evidently , my orig. dome were sw/out for the rectangle ones w/ push button on/off , as it went bad and I went to replace w/ same I also touched orange or white wite to metal and that wire wire started to melt the touching end ,but caught it in time that was all , just melted end of wire . also I noticed my headlite sw/ where you turn all the will turn on /off domes wasn't effecting my domes as they are operated by push but. on lite itself.workking fine though
I have the same push button light also have 2 capped wires one which is orange
Number of posts : 1878
Re: something wrong
Post by savage on Mon Feb 09, 2015 6:20 am
The orange is Hot all the time(also brake lights) dome lights use the ground from headlight switch to turn on light. Not positive but think dome is on the same fuse as Brake lights (15 amp)??
Re: something wrong
    Current date/time is Mon Apr 23, 2018 12:07 pm
