    Removing floor surfface rust and some discoveries
    steelrat
    steelrat
    Number of posts : 116
    Registration date : 2014-11-24
    Removing floor surfface rust and some discoveries Empty Removing floor surfface rust and some discoveries
    Post by steelrat Sun Jan 04, 2015 5:12 pm
    I removed most the surface rust today and discovered some areas of concern. My friend fabricator) housing the van at his garage has advised me to make templates of all peices to be replaced/welded. He will then plasma cut all pieces at his shop from 18 gauge and show me how to tack/weld in place. Open to any advice. Smile
    Areas needing repair are:
    floor by gas filler neck
    area behind passeger rear wheel well to back door
    behind passeneger seat, just behind wheel well.
    Removing floor surfface rust and some discoveries Gas_fi10
    url=https://servimg.com/view/19067990/87]Removing floor surfface rust and some discoveries Passen10[/url]
    Removing floor surfface rust and some discoveries Pasene10
    url=https://servimg.com/view/19067990/89]Removing floor surfface rust and some discoveries Passen11[/url]
    Number of posts : 2011
    Removing floor surfface rust and some discoveries Empty Re: Removing floor surfface rust and some discoveries
    Post by Barnabas Mon Jan 05, 2015 7:58 pm
    We all need friends who are fabricators. Your rust is not as bad as some of mine. Make sure to cut out all the rust, or it will keep growing.
      Current date/time is Sat Apr 27, 2024 12:49 pm
