    3 Pt. Belt installed
    stanyon
    stanyon
    Number of posts : 147
    3 Pt. Belt installed Empty 3 Pt. Belt installed
    Post by stanyon Tue Nov 11, 2014 3:23 pm
    3 Pt. Belt installed Sb_112
    Cold here so time to get back into the shop and work on the Truck. I had these belts so started by welding blind nuts on the back side to ease the installation.
    3 Pt. Belt installed Sb_211
    I moved the belt body around until I could use the double plate as a mounting point,
    this is behind the front wheels underneath.
    3 Pt. Belt installed Sb_311
    I placed the belts in the opening behind the seats, had to do a little adjustment to the inside wall but nothing extreme.
    3 Pt. Belt installed Sb_411
    Next I wanted to reinforce the rear door pillar as this would be the pivot point and take the most stress in the event a crash were to occur.
    stanyon
    stanyon
    3 Pt. Belt installed Empty Re: 3 Pt. Belt installed
    Post by stanyon Tue Nov 11, 2014 3:33 pm
    3 Pt. Belt installed Sb_510
    After I got the reinforcement welded in I then added two bridges to stiffen the pillar
    3 Pt. Belt installed Sb_610
    The attacement pivots all came out, I paced a seat in and the ran the belt to see where on the pillar I wanted the upper mount to be.
    3 Pt. Belt installed Sb_710
    The cover also needed a little adjusting but the metal is really soft and easy to work.
    3 Pt. Belt installed Sb_810
    Belts installed and working. Thanks to all of the previous posts from whom I grabbed Ideas and information. The hardest part was making sure that the seat belt body was set at the right angle to allow the belt to be extracted smoothly. Seemed like a couple of degrees of and the belt would not be released.
    Abitibi
    Abitibi
    Number of posts : 479
    Post by Abitibi Tue Nov 11, 2014 4:01 pm
    Nice work!
    Number of posts : 1466
    Post by uante Tue Nov 11, 2014 5:45 pm
    Yeah real nice! Wasn't a fan of seat belts in my youth, but I learned better Razz
    EcoPU
    EcoPU
    Number of posts : 104
    Registration date : 2013-08-28
    Post by EcoPU Thu Nov 13, 2014 8:17 am
    Looks great, good work. I need to learn how to weld!
      Current date/time is Sat Apr 27, 2024 3:51 pm
