Symptom
Around 950/1000 - 1900 rpm a High Squeel scream can be heard. Can accelerate/decelerate to make the problem stop.
After 30 - 40 minutes of driving/charging symptom is gone.
I have replaced the belt with a gator back and tightened the belt many times. The alternator is in the bracket as far as it can go outwards. I may try to order a slightly shorter belt. Engine is 1968 289 no A/C or PS.
Thinking I may need to purchase another alternator while I return this one to powermaster.
History
My van stopped running one day after being driven daily. It turned over but didn't fire. I tested the battery it was good and the carb was shooting gas. I tested the plugs and they weren't getting spark.
I replaced the starter solenoid, spark plugs, and installed a pmgr mini-starter. I also installed new #2 guage wiring from battery, starter, and engine ground.
The van started again. But now main symptom above appeared.
Starter solenoid part#
Standard Motor Products SS581
Spark plug#
Motorcraft BSF3 - no resistor
Powermaster 140 AMP Alternator#
8-57140
(Now seeing I should have bought a 3g 1-wire alternator for higher quality.)
I'm going to try to make a video for further diagnosis.
Thanks
Drew
History
Spark plug#
8-57140
Thanks
Drew
