    Throttle linkage ?
    Oscarm
    Oscarm
    Number of posts : 91
    Registration date : 2014-05-06
    Throttle linkage ? Empty Throttle linkage ?
    Post by Oscarm Sun Nov 09, 2014 5:34 am
    Putting a 5 liter /302 into a 65 Epup. What are folks doing for throttle linkage and gas pedal
    setups? What seems to work well for you ? (5.0, Edelbrock carb, C4 green dot trans)
    Most 'kit' solutions (Lokar) have short cables, and big dollars.
    Throttle linkage ? Empty Re: Throttle linkage ?
    Post by Twinpilot001 Sun Nov 09, 2014 6:59 am
    summitt= marine cables best- teleflex 3300 or 33c type. stainless cable is best!! cheers
    neondv8
    neondv8
    Number of posts : 278
    Post by neondv8 Sun Nov 09, 2014 2:57 pm
    I don't have the same set up as you, but I do have a lokar floor shifter. When I needed to replace the throttle cable I used a Bicycle cable from a tandem bicycle. It's stainless steel and worked good.
    Number of posts : 2011
    Post by Barnabas Sun Nov 09, 2014 6:14 pm
    The stock pedal, linkage, and cable for the 1965-1967 Econolines with a 240 engine work well and bolt right in. Vic usually has a few in stock.
    Number of posts : 864
    Post by Casimier Mon Nov 17, 2014 10:39 am
    I used a CSR 6' cable set up from Summit.
    I ran it from my existing 1965 throttle floor bracket assembly up behind the
    engine and attached it to a bracket that I fabricated that bolts to the intake manifold..
    kinda like an early mustang style.
    The cost was up there but under $70....I should have had Vic make me one.
    Would have saved a lot of time.
    But sometimes you want to do it yourself.
    Jim in NJ aka Casimier
      Current date/time is Sun Apr 28, 2024 2:51 am
