throttle linkage
dougtappan
Number of posts : 263
throttle linkage
Post by dougtappan on Sun Aug 07, 2016 4:06 pm
Well it's been 2 years since I tore the van apart and now I'm ready to put the throttle linkage back on but I must be missing a piece cause nothing is making much sense .....So if the g
Grand Master....Donnie or any else has pictures of the way the linkage is supposed to be set up I will have a starting point. Of the 3 manuals I have ,none show that linkage. Thanks in advance.
Number of posts : 11569
Re: throttle linkage
Post by donivan65 on Sun Aug 07, 2016 10:35 pm
Well the gas pedal connects to a long rod,,,,,it goes to a lever inside the doghouse above the clutch rod,,,,,then a shorter rod goes back from that lever towards the alternator to another lever on the intake manifold,,,,then another rod goes from that lever up onto  the carburetor
Number of posts : 1412
Post by Vantasia on Mon Aug 08, 2016 6:28 am
dougtappan wrote:Well it's been 2 years since I tore the van apart and now I'm ready to put the throttle linkage back on but I must be missing a piece cause nothing is making much sense .....So if the g
The shop manual van supplement clearly shows the entire linkage set-up from pedal to carb in two different diagrams? here, this is actually from one of Doni's older posts!:
http://www.servimg.com/image_preview.php?i=2123&u=12482430
    Current date/time is Thu Apr 26, 2018 3:43 pm
