    choke to start
    Number of posts : 359
    Registration date : 2014-09-26
    choke to start Empty choke to start
    Post by rocky69rhodes Mon Oct 27, 2014 8:51 am
    what is wrong i need to choke to start
    choke to start Empty Re: choke to start
    Post by Twinpilot001 Mon Oct 27, 2014 10:16 am
    likely lack of fuel in starting circuit!!-low fuel level in bowl?? Will it stay running?after initial start on choke?? will it run & drive as normal-without choke?
    Post by rocky69rhodes Mon Oct 27, 2014 10:30 am
    yes and yes Thanks
    Post by donivan65 Mon Oct 27, 2014 11:02 am
    ,,,make sure the points and timing are set correctly,,,,,,set the timing to around 7 degrees before top dead center,,,,,,
    Number of posts : 1412
    Post by Vantasia Mon Oct 27, 2014 12:37 pm
    If its a manual choke carb, of course you need to choke it to start cold by design! Getting to stay at idle is a little more tricky...once it warms a little, 5-10 mins gradually push the choke in until it holds idle on its own, set the idle about 600-700 rpm, they usually won't hold the 450 spec shown in the manual on modern gas. After timing, use a dwell meter to check the points...
    Post by donivan65 Mon Oct 27, 2014 2:03 pm
    check dwell before the timing,,,, changing the dwell changes the timing......
    Post by rocky69rhodes Mon Oct 27, 2014 9:46 pm
    Thanks everyone
    Post by Vantasia Tue Oct 28, 2014 4:02 am
    donivan65 wrote:check dwell before the timing,,,, changing  the dwell changes the timing......
    Good 'point'...and then re-check the timing!
    Post by donivan65 Tue Oct 28, 2014 9:25 am
    I don't need a choke to start my van,,,,,,,,pump it a couple of times,,,,,give it some gas to keep the RPMs up for a few seconds and I am ready to roll,,,,,,,,also make sure the mixture screw is adjusted on your carburetor,,,,,,,,,but I am running a Carter YF,,,,,,,you got a Rochester Monojet,,,,,,,but can anyone else here start their van without having to pull out the choke ?
    morbank
    morbank
    Number of posts : 161
    Post by morbank Tue Oct 28, 2014 10:26 am
    My choke was disabled when I got my van and Doni said, I am able to start pretty easily with just a few revs.
    Post by donivan65 Tue Oct 28, 2014 10:58 am
    ,,,so I would say,,,,,,if you got your electrical system adjusted correctly,,,,it should start with a few pumps of the gas pedal,,,,,,,,,,,however,,,,,I would say the choke weather is coming REAL soon to you people east of the Rocky Mountains,,,,,
    Post by Vantasia Tue Oct 28, 2014 12:49 pm
    donivan65 wrote:I don't need a choke to start my van,,,,,,,,pump it a couple of times,,,,,give it some gas to keep the RPMs up for a few seconds and I am ready to roll,,,,,,,,also make sure the mixture screw is adjusted on your carburetor,,,,,,,,,but I am running a Carter YF,,,,,,,you got a Rochester Monojet,,,,,,,but can anyone else here start their van without having to pull out the choke ?
    No, but with my new Daytona (Holley) carb, I pull the choke and turn the key and it starts instant every time without pumping the gas, like fuel injection! Then I pump it a few times and push the choke in half way and go, at first stop sign, I push it in all the way and the idle goes down to normal, about 650-700 on my tach. Same hot or cold weather, albeit, I park it in a heated garage in winter....hehehe....I know, you SoCal guys don't have those issues....what can I say...?
    Post by donivan65 Tue Oct 28, 2014 12:55 pm
    I guess thats why Rocky is complaining,,,,,,,,,he has to do all that extra work to get his van to start,,,,,,
    Post by rocky69rhodes Tue Oct 28, 2014 3:25 pm
    lol I push the choke back in as soon as it starts
    Post by donivan65 Tue Oct 28, 2014 4:08 pm
    aint it about time you go up to PROFILE and get yourself a new AVATAR?
    Post by Twinpilot001 Tue Oct 28, 2014 4:15 pm
    affraid ---SICK'EM Doni!! Sick'em!!! lol! lol! lol!
      Current date/time is Wed May 01, 2024 5:04 pm
