Tie Rod bar bent?
cali2chitown- Number of posts : 188
Tie Rod bar bent?
Re: Tie Rod bar bent?
Nobody knows if it's supposed to look like this?
Are you referring to the drag link? Here's a link with pics. Hopefully, this will help you out.
http://search.aol.com/aol/imageDetails?s_it=imageDetails&q=66+ford+econoline+drag+link&s_chn=prt_ct5&v_t=comsearch&b=image%3Fenabled_terms%3D%26s_it%3Dcomsearch%26q%3D66%2Bford%2Beconoline%2Bdrag%2Blink%26s_chn%3Dprt_ct5%26oreq%3D7f16c6a7d7644fc29077a3c9b101f7e0&img=http%3A%2F%2Ffcrcmachine.com%2Fimages%2FI14215754&host=http%3A%2F%2Ffcrcmachine.com%2Fi-14215755-rare-parts-drag-link-1961-1967-ford-econoline-e-100-e-150-25781.html&width=85&height=85&thumbUrl=http%3A%2F%2Ft3.gstatic.com%2Fimages%3Fq%3Dtbn%3AANd9GcRUkSJ6_43EXfW-63WMjX9F0xMes8FEyyudEhARZn0dtBp13RXBMYLjEj4&imgWidth=200&imgHeight=200&imgSize=3002&imgTitle=66+ford+econoline+drag+link
- Number of posts : 2086
I think your referring to the spindle connecting rod. I don't think it should look like that, but I've had a few beers, I'll refer to mine in the AM
It's the bar that each Tie Rod End connects to. I already have a new drag link and sway bar mounts from rare parts, great place vanny.
That is the CenterLink,,,,,it connects the 2 tie rods together and you adjust the toe in with it and it aint supposed to be bent,,,,,however,,,,a lot of them are from people running a floor jack under the van when lifting it up and catching on it or lowering it on a jack stand .........
Thanks Donivan! I wasn't really sure if it was made like that or not. Now I need to figure out a way to get it bent back
Sy Hollinshead- Number of posts : 466
Blow torch and a vice should sort that out.
The passenger side has left hand threads in it so you kind of need a tie rod screwed in to protect the threads,,,,I dont think that center link is very tough,,,,,maybe put a block of wood under the tie rod,,,,,use a hydraulic jack under the bumper to jack the bend down into place.....it don't have to be perfect,,,,
I was thinking pretty much the same thing. Put the old tie rod end back in use a jack instead of heat at first. Been working all weekend and hopefully should be able to get to it tomorrow.
