+8
rehreh07
cali2chitown
larrytech1
bugman
12 posters
    1964 Ford Econoline New Rims and Tires
    bugman
    bugman
    Number of posts : 72
    Registration date : 2011-12-17
    1964 Ford Econoline New Rims and Tires  Empty 1964 Ford Econoline New Rims and Tires
    Post by bugman Sat Apr 26, 2014 8:36 pm
    Rims are 15X7 in the front with 215/60's and 15X8 in the rear with 225/60's with an offset of 4 inches. The fit is perfect and does not rub when you fully turn with stock springs. Also with the rear fully loaded the tires do not rub on the inner part of the fender. I would not suggest going any larger in the rear unless you rolled the rear fenders. 1964 Ford Econoline New Rims and Tires  Van_ri12
    Number of posts : 655
    1964 Ford Econoline New Rims and Tires  Empty Re: 1964 Ford Econoline New Rims and Tires
    Post by 61econoline Sat Apr 26, 2014 8:38 pm
    looks sharp
    larrytech1
    larrytech1
    Number of posts : 34
    Registration date : 2011-09-03
    Post by larrytech1 Sat Apr 26, 2014 9:04 pm
    looks great  , I just picked up some wheels for my 67 econup ( have not got tires on them yet) but, rims are all 15 x 7 ( with 3/8" offset) ….. tires will be 205/60/15 front & 215/60/15 rear.
    Larry/tampabay
    cali2chitown
    cali2chitown
    Number of posts : 188
    Post by cali2chitown Sun Apr 27, 2014 2:09 pm
    That looks great! Where did you get them bugman?
    bugman
    bugman
    Post by bugman Sun Apr 27, 2014 8:27 pm
    We got them from Summit Racing, free delivery, exactly as ordered, two days door to door
    rehreh07
    rehreh07
    Number of posts : 73
    Registration date : 2014-05-02
    Post by rehreh07 Wed May 07, 2014 1:04 pm
    Is the 4in offset all the way around ?? Or just in the rear????
    Post by vanny Wed May 07, 2014 6:02 pm
    Good info Bugman and nice looking Econo! I Really like the look of those rims!
    bugman
    bugman
    Post by bugman Wed May 07, 2014 7:58 pm
    The offset of 4" is all the way around.
    rehreh07
    rehreh07
    Post by rehreh07 Wed May 07, 2014 9:19 pm
    Would 4.5 " offset work????
    bugman
    bugman
    Post by bugman Mon May 12, 2014 3:37 pm
    rehreh07 not with the size tires I have on it. I am trying to figure out how to upload a picture to show you.
    rehreh07
    rehreh07
    Post by rehreh07 Tue Jun 03, 2014 7:18 pm
    I really like the US Indy mag wheels. The closest size that they have available to the size u stated above is
    15x7
    3.75 backspace
    5mm offset
    Will that wheel fit free and clear on my 63 e van front and back?????
    Number of posts : 1422
    Post by Magic Bus Tue Jun 03, 2014 8:02 pm
    rehreh07 wrote:I really like the US Indy mag wheels. The closest size that they have available to the size u stated above is
    15x7
    3.75 backspace
    5mm offset
    Ive looked at those wheels, I absolutely love them, they are quite similar to the ones I have on the Magic bus...In the past I have measured tested and looked, the front is not a problem with that size and I believe they will work on the back but it is gonna be close to rubbing.  I still yet may buy a set of those, whats the best price you found on them?   Seems like I had found around $150 each?
    1964 Ford Econoline New Rims and Tires  Us_mag10
    rehreh07
    rehreh07
    Post by rehreh07 Tue Jun 03, 2014 8:16 pm
    that's the same best price I found
    rehreh07
    rehreh07
    Post by rehreh07 Tue Jun 03, 2014 8:17 pm
    so you think that they're clear just fine?
    Post by Magic Bus Wed Jun 04, 2014 3:37 pm
    rehreh07 wrote:so you think that they're clear just fine?
    5mm is not much, If I was betting Id say they will work, but I dont want you to buy them based on my opinion, You really need to remove your rear wheel, drop a straight edge down from the inside of the fender lip and measure it. It would be nice if a local place could order them for you and "test" fit them before you obligate to purchase?
    Number of posts : 2086
    Post by Seth G Wed Jun 04, 2014 5:53 pm
    That's -5mm offset
    FCC
    FCC
    Number of posts : 295
    Post by FCC Thu Jun 05, 2014 11:07 am
    I'm so confused.   What is 3.75" back space with a 5mm offset?  Should the 5mm offset be parenthetical? As in, 3.75" back space (-5mm offset).
    According to everything (I thought) I know, Back space (american way) = Offset (most of the world way)= Back space (american way).   Its two ways of stating the same thing.
    (**tons of deleted mumbo-jumbo was here**)
    I don't think they should both be used in the same sentence, should they?
    -this confusing and makes my brain hurt!!  Make it stop!!!!!!!
    Post by Seth G Thu Jun 05, 2014 12:55 pm
    lol, yes they are synonymous. I suppose they listed it both ways to make it easier ironically. And the true test of fitment is measurement with a framing square from the face of the hub. Width is somewhat universal but suspension difference, ride height etc will alter what is possible in diameter or in a combination of the two. I had some detailed notes of measurements I've taken on the rear but can't find them. Iirc, there is a 1/2" offset from the centerline of the width possible between the inner wheel well on the outside and the leaf springs on the inside and the possition of the hub face, but I don't remember in which direction. I want to say the hub is offset torwards the outside of the van and you need a -12mm offset rim to recenter if going for maximum wheel width with an 8" or 9" rim and the appropriate tire combo to get there. But if going narrower then getting an even outside tire face front to back may be more important to you.
    Post by Magic Bus Thu Jun 05, 2014 7:37 pm
    Post by Guest Mon Jun 09, 2014 10:22 am
    How did you lower your van, it looks great!
    bugman
    bugman
    Post by bugman Mon Jun 09, 2014 3:55 pm
    Vintage Metal wrote:How did you lower your van, it looks great!
    I have not lowered the van at all. The suspension is stock. I only replaced the shocks because the original ones were rusted through but replaced them with the stock sizes.
    Post by Seth G Sun Jun 15, 2014 5:21 pm
    bugman, how much space is left up front lock to lock with the 215/60's? I'd like to go with a little wider 225(.4" wider, .2" clearance either way) tire if possible so I can have the same wheels/tires all around. I'm looking at 0 offset/4" backspace 15" x 7" w/225/60's or 17" x 7" w/225/50's
    For anyone else who has read this thread, I remeasured the rear hub clearance, and have realized I mis-spoke, you'll need a positive offset to recenter the wheel in the rear for max possible width. I remembered correctly that the hub is offset to the outside of the van but got mixed up on + and -. A negative offset will move the wheel to away from the hub, not really what you want in the rear unless you're going with 7" rims
    The measurements side to side I came up with from the mounting face are: approx. 4 7/8" clearance to the fender lip, approx. 5 7/8" clearance to the leaf spring band.
    So, to recenter the rim, a +12mm offset is needed. According to my figures this yields a maximum tire section width of 265 or approximately 10.4"(a 275 may be possible but you would definitely need to roll the fender lip), for example a 15" x 9" rim with +12mm offset with 265/50 tire should fit.
    bugman
    bugman
    Post by bugman Sun Jun 15, 2014 7:39 pm
    We will measure lock to lock and post a reply.
    bugman
    bugman
    Post by bugman Tue Jun 17, 2014 4:59 pm
    [quote="Seth G"]bugman, how much space is left up front lock to lock with the 215/60's? I'd like to go with a little wider 225(.4" wider, .2" clearance either way) tire if possible so I can have the same wheels/tires all around. I'm looking at 0 offset/4" backspace 15" x 7" w/225/60's or 17" x 7" w/225/50's
    From lock to lock there is 1.5 inches from the inner part of the tire to the spring in the rear (front tire) and 2.25 inches from the inner part of the front tire to the spring.
    Post by Seth G Tue Jun 17, 2014 10:04 pm
    Thanks! That really helps me out  Very Happy  How's it look for clearance to the fender? Might go -6 offset if possible.
      Current date/time is Tue May 07, 2024 3:39 pm
