I have some 14 in slots and the tires are p225/70/r14. They rub on the front. The speedo is about 5 mph fast. What size should I buy that won't rub? What would be the correct size to buy? Also,, if I wanted to lower the van by going with smaller tires how small could I go without it looking stupid?? Any thoughts and suggestions would be great.
What tires for 14in rims??
rehreh07- Number of posts : 73
Registration date : 2014-05-02
- Number of posts : 2086
Re: What tires for 14in rims??
Those are kinda tall tires @ around 26 1/2" diameter. Where are they rubbing? You didn't mention the rim width or offset? I assume they are either 7" or 8" rims based on those tires. If they are 8's you're going to be pretty limited on going much, if any, narrower in section width, but can shorten the aspect for a smaller diameter tire like a 225/60 which would be 24.5" diameter tire. It's hard to say what you could run without that information. But I would think a 205/65 would be a safe bet on a 7", that's around a 25.5" tall 8" wide wheel. Could probably even go with a 215/60 which would be a little wider, ~8.5" and a little smaller around, ~25". Or a 205/60... It all depends on what you want it to look like, what the backspace is and what you measure. For me, if you go much below 25" wheel they start to look to small, but that's just me.
Tires and wheels are such a particular thing depending on what an individual wants it to look like. Do you like a tire that bulges out from the rim or stock looking, alot of side wall or just a little, wide tire or narrow? etc. Best thing you can do is some research and careful measuring with a square from the mounting face. Could always just take it to the tire shop. Good luck.
They came with a parts truck with new tires on them and balanced. I can't tell if they r rubbing on the top or the sides. I like the width but would be ok if they where a little narrower. So u think a 205/60??
Ddavllc- Number of posts : 127
Registration date : 2013-11-07
When I first got my truck there were 15's on it. They rubbed every time I hit a bump. It got so bad for me I clinched my but cheeks together every time I even saw railroad tracks while driving. The problem for me was one of shocks and front springs. The minute I change them i can take speed bumps and there is no way I can hit
Kind of a long way around saying the problem might be with your suspension and not a tire and or rim selection.
