ThomastheTankVan
    Alternator or Voltage Regulator
    ThomastheTankVan
    ThomastheTankVan
    Number of posts : 25
    Registration date : 2014-03-13
    Alternator or Voltage Regulator Empty Alternator or Voltage Regulator
    Post by ThomastheTankVan Sun Mar 16, 2014 3:31 pm
    I put a brand new battery in my 1965 A100 on Monday. And has been running fine. Then last night started right up and then died. Battery was dead. Will jump off no problem but then die right away. Sounds like alternator right? Well the alternator isn't factory some Remy Delco 1100681. And I also found the voltage regulator and nothing was connected to it. But it's been running for a week.
    So question is what's what? I brought the alternator to autozone and it tested bad. But why was the voltage regulator disconnected? And how was it running without it. I think the alternator is externally regulated too. So I'm lost.
    Help.
    Number of posts : 8729
    Alternator or Voltage Regulator Empty Re: Alternator or Voltage Regulator
    Post by dix Sun Mar 16, 2014 3:36 pm
    I think the gm/ ac delco had the regulator in the alternator BUT being more of a mopar guy i could be way off.
    Post by Twinpilot001 Sun Mar 16, 2014 4:12 pm
    most delco alts= we use todsay are internally regulated!!! no regulator outside!!
    ThomastheTankVan
    ThomastheTankVan
    Post by ThomastheTankVan Sun Mar 16, 2014 5:12 pm
    So maybe thats why the voltage regulator was disconnected? Because the voltage regulator isn't stock either, I think its an electronic one. The replacement alternator I found is externally regulated. And the one that was in it is obsolete so I can't find any info on it.
    A lot of stuff was disconnected though. Like the wipers, washer pump, and heater. And I plugged them all back in and work just fine. So maybe it was disconnected by accident?
    Last edited by ThomastheTankVan on Sun Mar 16, 2014 5:30 pm; edited 1 time in total
    Post by donivan65 Sun Mar 16, 2014 5:20 pm
    ..the one on the left has the regulator built inside it,,,
    Alternator or Voltage Regulator Repai103
    BoneMan
    BoneMan
    Number of posts : 169
    Registration date : 2011-06-23
    Post by BoneMan Sun Mar 16, 2014 5:53 pm
    Sounds like maybe someone upgraded it to electronic voltage regulator, and left the old mechanical voltage regulator - disconnected.
    http://www.mymopar.com/charging.htm
    According to this site, the delco 1100681 is externally regulated.
    http://www.partsnetworkco.com/Delco-1100681-Replacement-Alternator-Brand/dp/B00CCUV7V2
    Hopefully you just need a replacement alternator of the same type/equivalent to the one that tested bad.
    Best luck getting it going.
    ThomastheTankVan
    ThomastheTankVan
    Post by ThomastheTankVan Sun Mar 16, 2014 6:04 pm
    Mine is the one on the right. I took some pictures, I'm trying to post some soon. Thanks.
    ThomastheTankVan
    ThomastheTankVan
    Post by ThomastheTankVan Sun Mar 16, 2014 6:09 pm
    Well apparently I can't post pics for 7 days cause I'm a new member. Thats silly.
    Post by dix Sun Mar 16, 2014 6:15 pm
    The mopar regulator is avail. but you have other wiring issues going on by the po.
    Dawgboy
    Dawgboy
    Number of posts : 278
    Registration date : 2013-04-20
    Post by Dawgboy Sun Mar 16, 2014 10:00 pm
    Hey, so here is a web site you will also want to look at... That ammeter in the dash is a ticking time bomb that wants to turn your van into a dumpster fire. Mine was completely fried and the two ammeter wires were melted together for their entire length, yet the van still ran...
    http://www.madelectrical.com/electricaltech/amp-gauges.shtml
    Number of posts : 1148
    Post by jkr Mon Mar 17, 2014 4:22 pm
    I have to disagree on the ammeter as a cause of fire. it is more or less a fuse, to much current and it will burn open not short to ground as a rule. the real culprit in old dodge vehicles is the mechanical voltage regulator. and remember they go through your ammeter so that's why it (ammeter) gets a bad rap. wires get brittle and the insulation breaks off, the connections get loose, and or the regulator sticks and overheats more than anywhere else at the loose or weak connections causing problems.
    last spring for no reason I could see a wire burnt through the back of my headlite switch, or so I thought. the ground on the right front broke off and the switch searched for a place for the current to go. it found it out the back of the switch to ground. more problems from things like that than any. just my 2 cents worth...
    ThomastheTankVan
    ThomastheTankVan
    Post by ThomastheTankVan Wed Mar 19, 2014 5:40 pm
    Well, problem solved.
    Turns out it was the voltage regulator. The one that was in there was HAND MADE. The previous owner fancied himself a engineer apparently.
    Oh course I was lost so I took it to a shop. As I already knew the alternator was a GM alternator the just matched the voltage regulator and shazam! All is well.
    Just wish I knew more about this could have saved me $120.
    Thanks for all your help guys, my custom convertible once again cruises San Diego.
      Current date/time is Sat Apr 27, 2024 2:30 am
