The doghouse in my van came with shiny new nuts/bolts fastening it to the floor... I suspect it didn't use nuts/bolts originally though, because it would be a PITA to remove the doghouse that way; holding the nut under the floor and wrenching the bolt from above. Was there an easier fastening system originally? Google didn't reveal anything. I want to explore options before I proceed welding the nuts under floor...
Doghouse fasteners - what did these come with??
gotdurt- Number of posts : 69
Registration date : 2013-12-31
Casimier- Number of posts : 864
econopoor- Econoline Guru
- Number of posts : 1747
The fender nuts that casimier posted are not the correct item to use. Sorry Jim. The fender nuts won't fit over the lip on the doghouse opening in the floor. The correct thing to use is cage nuts. the early ones were 5/16ths fine thread and later Econolines used 5/16ths coarse thread. The fine thread ones are no longer available but the coarse work fine.
http://www.ebay.com/itm/Ford-Lincoln-Mercury-cage-nuts-5-16-18-caged-nut-/370530917700?pt=Motors_Car_Truck_Parts_Accessories&hash=item56455d1d44&vxp=mtr
You can get them in bulk cheaper.
Cool thanks. Hopefully nothing was modified in a way that I can't go back to the cage nuts... As for fine or coarse, coarse is faster anyway.
gavinator- Number of posts : 42
Registration date : 2014-01-14
Here's a cheaper source. I'll be buying some soon myself.
http://www.steinertractor.com/IHS946-cage-nut?CID=IHS946&gclid=CLTk4Y20sr4CFQEdOgodPGYAgA
mexbob- Number of posts : 19
Registration date : 2014-11-15
This is where I purchased mine, two(2) packs of ten(10) each at $7.00 each.
http://www.mcmaster.com/#90680a146/=vg7dde
