I am in the market for a new set/used set of rims for my 66. Question, what are you guys running on your dodge vans? Any pictures you have would be helpful. Thanks
J
J
jfox wrote:maybe its just me but the difference in stance between a 14' and 15' rim looks huge on these vans. I'm really torn between the vintage look and the "hot rod" look.
Gileadgarage wrote:I was just thinking about wheel/tire size too. I am seriously considering 15x8 R, 15x7 F, i think I want to go with 7" Fronts (if they fit OK?) and maybe some 225 or 235/60/15. I realize they will make steering at stop a bit harder, but i always try to turn while rolling anyway, think I can live with it.
I'd love to see more pics of 15x8 rear and and or 15x7 front! And open to recomendations on tire sizes
Thanks,
Mark
So true about handling. Here's what i ended up with. Removed beat up stock 15" rims/wheels..New fronts 14x7 with 225/60 and rear14x8 235/60..all four BfGoodrich TA's on a set of US(?)slotted mags then per Dodge Man i removed two leafs on each corner then re pinned. I then took it to the shop for alignment. Drives so much better. I can actually put my foot in to it around corners now without the oh shit tilt factor. Sits exactly how i wanted it to. Any thoughts on shocks? Thanks again guys for the tips and such.dodge man wrote:I removed 2 leaf springs from all corners, it still handles fine and rides better.
For now i went with the bottom two. My plan is to have a company here in town(national spring) re make me a proper spring pack to accommodate its new stance. regardless i'm not experiencing any issues thus far and loving its new found "attitude"dodge man wrote:on the front witch 2 springs did you remove ? I ask because I removed the 2 center leafs and its not as low as your, I want mine lower,
john
