by donivan65 Fri Jan 17, 2014 10:30 pm
You need to see if the transmission is actually going all the way into 2nd gear,,,,,,,so unhook the 2nd and 3rd gear rod at the transmission, see if both levers on the trans are tight,,,,,,,,move the lever on the trans by hand,,,,,see if the detents are holding,,,,,you should feel some clicking as you move the lever from 3rd to neutral to 2nd and the lever should kind of stick in each of those positions and not move easily from 2nd to neutral,,,,,,so see what you got,,,,,then push the rod all the way forward which makes the gearshift lever go into 2nd and see if it lines up when you shift the trans lever is in 2nd,,,,,you are comparing the gearshift lever in 2nd gear to the transmission being in 2nd gear,,,,see if they are in adjustment....worn out motor and transmission mount will also cause the trans to pull itself out of gear......
