sounds like a vacuum leak, spray some soapy water around the carb and intake when its running and see if the idle changes when you spray
+7
Scotts_A100
A100 Wrench
thunderbirdesq
11 posters
New A108 project
- Post n°26
Re: New A108 project
thunderbirdesq- Number of posts : 43
Registration date : 2012-11-08
- Post n°27
dodge man wrote:sounds like a vacuum leak, spray some soapy water around the carb and intake when its running and see if the idle changes when you spray
That's what I thought at first... I've tried that, doesn't appear to be leaking anywhere... I would think a vacuum leak would be pretty consistent... it just all of a sudden starts working fine, and then relapses into running rough seemingly at random. Plus the carter bbs that I have idles fine on there, it just won't run worth a damn going down the road!
- Post n°28
then it must be you have 2 bad carbs, check on ebay or somewhere to find you a used one, I see rebuilt carbs on ebay that may be what you'll need to do, I don't know if your is worth rebuilding with this problem
A100 Wrench- Number of posts : 572
- Post n°29
Have you tried to richen the idle mixture? Sound lean.
- Post n°30
I agree that it does seem lean, I have tried adjusting the mixture screw when it does this and it does affect the idle quality but it never clears up entirely. However, on a brighter note, it seems it may have "fixed itself"... I rans some errands and drove it about 25 miles last evening and it idled fine the whole time. Gonna drive it to work today and hopefully it does the same. I *HATE* not knowing what is going on there though, drives me crazy!
- Post n°31
She's bonafide!! And the idle issue? ...it fixed itself, ha! We did over 800 miles in this weekend and it idled fine the whole time. It does use a bit of oil, I had to add two quarts over the course of the trip. It appears to have a leak at the rear of the valve cover and a small drip where the oil pressure line hooks up. I never see any blue smoke so I don't think it's burning much. Gonna get the leaks sealed up and just keep my eye on it.
Cruises at 65-70 just fine on flat land, we climbed some mountains in PA on rte 80, dropped to 55 or so on some of those but I can live with that. We've got a few ideas to increase the "creature comfort factor" for these road trips too so I'll update as that happens... good times!
- Post n°32
glad to hear shes running good,
- Post n°33
16mpg... roughly.
Dawgboy- Number of posts : 278
Registration date : 2013-04-20
- Post n°34
16? I'm getting a solid 20MPG out of my 170 with a BBS on it...
- Post n°35
In a long wheelbase 108 loaded with three large dudes and a full compliment of rock and roll gear though? We were climbing some mountains too... I mean, yea, more would be better, but I was pleased.
- Post n°36
Congrats on the successful trip! Sounds like your oil usage might be resolved or at least minimized once you replace the seals.
- Post n°37
Rollin' on down the road...
- Post n°38
You have a point there, mine's a shorty. I definitely get worse mileage at freeway speeds than tooling around town... I think you can do better with some tuning though... Congrats on roadworthyness too. It's a great feeling!
- Post n°39
I'm assuming that's your band in that clip...You guys sound Great!!! I think a Vintage Van fits your group perfectly!
- Post n°40
Yea, we were cruising at 70 most of the time. All the aerodynamics of a cardboard box in a hurricane, ha! I have to say though, this dodge handles much better than any of my econolines, especially at freeway speeds. More stable.
I agree, a little tuning and I think I can improve the mileage a bit. I did install an electronic dist and module and it seems to have a bit more pep and starts easier too.
That's us, The Telltale Signs. Thanks man! Haha, yea my guys were a little hesitant at first but after this weekend, they're all on board. We had a blast in this ol' tin can!
