For those of you that have installed AC in your A100s what size condenser did you use? and where/how did you install it. What type fan... electric/ or mechanical 7 blade with clutch ? I am going to install a 19x30 aluminum rad with shroud also. Also making a low compressor mount ( to keep the top of engine uncluttered (273)). any input. Good or bad .
AC condensor question,
