    How do you replace the Pedal seals for brake and clutch?
    AZ SuperVan
    AZ SuperVan
    Number of posts : 219
    Registration date : 2013-09-12
    How do you replace the Pedal seals for brake and clutch? Empty How do you replace the Pedal seals for brake and clutch?
    Post by AZ SuperVan Fri Nov 01, 2013 2:06 pm
    I bought new seals that fill the gap around the brake and clutch pedals where they go through the floor. I just can't figure out how these guys can go around the pedal shaft. Do they have to be cut?
    Bill in AZ
    Carl
    Number of posts : 143
    How do you replace the Pedal seals for brake and clutch? Empty how to replace pedal seals
    Post by Carl Fri Nov 01, 2013 11:08 pm
    Did mine from the top, but had to take off the pads first. -do not have to cut anything
    AZ SuperVan
    AZ SuperVan
    How do you replace the Pedal seals for brake and clutch? Empty Re: How do you replace the Pedal seals for brake and clutch?
    Post by AZ SuperVan Sat Nov 02, 2013 8:59 am
    So you were able to stretch them out far enough to go over the metal parts?
    Carl
    How do you replace the Pedal seals for brake and clutch? Empty replace pedal seals
    Post by Carl Sat Nov 02, 2013 12:35 pm
    yes, they stretched, used some dishwash soap to help
      Current date/time is Thu May 16, 2024 9:02 pm
