+4
chainsaw
8 posters
    Almost had a fire
    chainsaw
    chainsaw
    Number of posts : 226
    Almost had a fire Empty Almost had a fire
    Post by chainsaw Thu Oct 24, 2013 11:42 am
    I was checking trans fluid with the truck running and noticed gas dripping fast out of the fuel preasure regulator. It was running down the valve cover right to the exhaust, If I had been driving and the engine been hot I probably would have burned down the truck. I'm going to install a fire extinguisher or two right away. I'm feeling lucky, maybe I should buy a lottery ticket also.
    Almost had a fire Empty Re: Almost had a fire
    Post by donivan65 Thu Oct 24, 2013 12:07 pm
    I don't know what engine you have, but a 6 cylinder needs 4 to 6 pounds of fuel pump pressure to the carburetor,,,,,if the carb don't like that, then the needle, seat or float aint doing its job,,,,,,unless you have some other reason for a regulator in the system,,,,,,also a piece of 5/16" metal brake tubing  from the fuel pump to the carb is a safer way to go instead of rubber,,,,,,,this is what I am thinking right now,,,,,
    chainsaw
    chainsaw
    Post by chainsaw Thu Oct 24, 2013 1:47 pm
    It's a 302 swap with edelbrock carb and small elect. fuel pump. Tha carb didn't like the higher preasure so I put in the regulator to knock it down to 4 1/2 -5 lbs preasure . I should have bought a new regulator ( I have a new one now) instead of using one that had been in my parts box for 20+ years.
    Post by donivan65 Thu Oct 24, 2013 2:34 pm
    They make adjustable pressure fuel pumps or maybe you can install a regulator somewhere along the frame to cutdown on fire hazards,,,,,
    Number of posts : 1778
    Post by m1dadio Thu Oct 24, 2013 8:19 pm
    Ya brother that was a message from that great van place in the sky
    Almost had a fire Dscn0411
    m1d
    Number of posts : 1422
    Post by Magic Bus Fri Oct 25, 2013 2:28 pm
    donivan65 wrote:I don't know what engine you have, but a 6 cylinder needs 4 to 6 pounds of fuel pump pressure to the carburetor,,,,,if the carb don't like that, then the needle, seat or float aint doing its job,,,,,,unless you have some other reason for a regulator in the system,,,,,,also a piece of 5/16" metal brake tubing  from the fuel pump to the carb is a safer way to go instead of rubber,,,,,,,this is what I am thinking right now,,,,,
    I bought the tubing yesterday and am not driving Magic again until after that is taken care of!
    Number of posts : 466
    Post by Sy Hollinshead Fri Oct 25, 2013 2:30 pm
    Its actually surprisingly difficult to ignite fuel on an exhaust. Almost impossible, although the tiniest spark will do the job....!!
    chainsaw
    chainsaw
    Post by chainsaw Fri Oct 25, 2013 2:48 pm
    Sy Hollinshead wrote:Its actually surprisingly difficult to ignite fuel on an exhaust. Almost impossible, although the tiniest spark will do the job....!!
    That makes me feel better, but I still bought a fire extinguisher.
    Number of posts : 322
    Post by Wheelie Fri Oct 25, 2013 4:04 pm
    Fire extinguishers should be in any car thats carbureted. Or any car for that matter. Yesterday I saw an rx-8 that looked pretty new and it was smoldering away on the side of the road. I have one in my daily and in my van. They are definitely cheap insurance!
    Number of posts : 1747
    Post by econopoor Fri Oct 25, 2013 5:13 pm
    I have at least one extinguisher in every vehicle I own. I will not drive without one. I've had four car fires over the years. I can't tell you how many I've seen over all my years driving a truck. Cheap Insurance!! It can and will save your butt. I have them all over my house and shop as well. Had to fight my way out of a burning house once. I want all the help I can get.
    Dawgboy
    Dawgboy
    Number of posts : 278
    Registration date : 2013-04-20
    Post by Dawgboy Fri Oct 25, 2013 8:56 pm
    I once ended up with a girlfriend for a while after pulling over to put out the fire in he VW bug... Carrying an extinguisher is smart for many reasons.tongue
    Post by Sy Hollinshead Sun Oct 27, 2013 10:45 am
    Also, a battery cut out switch located as close as possible to the battery, and within reach of the drivers seat is a very good idea.
    Mine is on the battery box.
    Almost had a fire CIMG1413-1
      Current date/time is Wed May 01, 2024 10:51 pm
