Hey guys,
3 Qs for you.
1. I have blinker issues. The issue is the return does not work on my blinker so I find myself running with the blinker on, like a grandma in a caddy... I cannot hear the solinoid as it's a Ron Francis replacement and very quiet, and I don't notice the indicator lights as they are kinda dim in daylight, and way out of the line of sight when driving.
Has anybody added a buzzer or light to both sides to avoid this pitfall? If so, how did you wire it? Boneyard components???
2. one of my tail lights just won't hold contacts with the bulb any more. I had taped it and wedged it before, but that no longer works. what's the best way to fix this? it's the left side rear, so no access to the back of the light...
And last,
Im running the OEM 37amp alternator and OEM actually, the original Voltage regulator under the dash. All my lights and stuff have a slight pulse to them. I read that there is an electroic replacement VR that wires right in and looks original. I als read in a thread here that it's not compatible with pre 67 alts. Is that true? Can I run one? If so, part numbers?
Thanks!
3 Qs for you.
And last,
Thanks!
