    wheel backspacing, all models
    chainsaw
    chainsaw
    Number of posts : 226
    wheel backspacing, all models Empty wheel backspacing, all models
    Post by chainsaw Sun Sep 22, 2013 7:33 pm
    I know this is getting old, but on the pictures of trucks I like they might list the wheel size but not the backspacing. People talk about putting 10'' wheels under their econolines but I can barely  fit 7'' rims under mine without rubbing. Please post pics of your tire and rim combos with width and BACKSPACING and even tire size if you want, and if its a stock rear end or modified, on all vans and pickups, ford ,chevy and dodges. Thanks.
    Mine--14x 6 with 195/75/14, 375 backspace, stock 9'' rear end
    wheel backspacing, all models Econoline006_zpsb5913582
    wheel backspacing, all models Empty Re: wheel backspacing, all models
    Post by G-Man Sun Sep 22, 2013 7:44 pm
    Don't know if this will help, but they make benders for wheel wells to give more room
    Number of posts : 3046
    Post by RodStRace Mon Sep 23, 2013 8:22 am
    As you have figured out, a 10" wide wheel will not fit the stock wheelwell.
    You have to raise the suspension so it sticks out of the body (not 10 wide, but you get the idea)
    wheel backspacing, all models 375845683_82852c7e8a
    cut out the lip and add a flare,
    wheel backspacing, all models 26217410002_large
    or "tub" it with bigger wheelwells and a narrowed axle.
    wheel backspacing, all models 0909tr_03_z+1967_ford_econoline_van+right_side_angle
    Which direction you choose will determine what offset to use. The first 2 require a big offset. The last can use any offset if the axle width is determined using the wheel spacing.
    chainsaw
    chainsaw
    Post by chainsaw Mon Sep 23, 2013 10:16 am
    A few of the wheels I'm looking at list both a 4 1/2 and a 3 3/4th back space on a 8'' rim. I'd like to see pics of what different backspace's look like on the stock rear end of the econoline. I thought dodge and chevy people might like to know also, that's why I said show them all.
    Post by RodStRace Mon Sep 23, 2013 5:58 pm
      Current date/time is Sun May 12, 2024 2:48 am
