Got a couple questions about adding a front sway bar to my A100 pickup V8. First, if the truck did not have one..can it be added? Second , is it worth doing ? Third if I were to add disc brakes at some time, would the sway bar be a problem ?? Thanks guys.
front sway bar questions????
- Number of posts : 8731
Re: front sway bar questions????
Yes it can be added and you can see our disc brake set up this week end..Scottie out of Ohio has a lot of parts at better prices than you will ever find. plan on climbing under some trucks this week-end...and we will test you after you get back here...
