Hi guys,
Earlier this year I picked up a '68 A108 from a friend of mine. This thing is very cool. I race motorcycles so I bought it for the purpose of transporting my race bike and all the crap that goes with it to the track and back. Also to camp in!
Shortly after I bought it, I noticed the rear right wheel cylinder was leaking pretty bad. When I opened up the reservoir on the top of the master cylinder (dual circuit), I noticed the rear reservoir was empty so I put fluid in, pumped it up and drove for a month (which means 4 times cause I avg only once a week). In that time the brakes felt great at the start and would gradually get worse as the fluid leaked out the rear cylinder.
So I finally order a new one through JCwhitney. I swap it out, bleed it and wow the brakes feel amazing! I head out to one of the tracks and sit in some pretty terrible traffic, van gets hot, does some vapor locking, and the brake pedal gets really stiff and requires 2-3 times the pressure to get it to stop. Then they lock up on me, smoke coming from rear right wheel. I use a couple flat heads and adjust way out then back to normal and make the rest of my drive just fine. At this point I'm thinking ok I overfilled the reservoir and left no room for expansion so I take some fluid out. I also adjust both rear brakes to the right amount of drag. Now, I complete a couple long drives (in heat) with no lock ups but the pedal getting really stiff.
Then I drive home from the racetrack yesterday (keep in mind the van has been in the sun at the hot racetrack all weekend) and as soon as I start it up, before motor is up to temp even, the pedal is stiff immediately. I manage most of the drive home without using the brakes. I get home unload my stuff and start her back up to park and the brakes are locked up. I adjust the pedal way out and I can hear the creak of the springs pulling the wheel cylinders back. It definitely resets because leaving the pedal adjusted all the way out, unlocked them and put all the braking action at the floor.
A couple of other things I've noticed.
1. When I was bleeding the brakes (old way, pumping pedal), the first half of the stroke produced what looked like a tiny fountain of brake fluid in the rear port of the reservoir. My only experience is with single reservoir brake systems so I'm not sure what's happening here.
2. Plenty of meat on the shoe, lining is somewhat damaged from brake fluid. I used lots of brake clean when I swapped cylinders.
3. Lines are hard lines, fluid does move through them (saw when bleeding)
4. No visible leaks anywhere
5. Pedal adjustment works well and is not tightening or loosening on its own.
Not sure what to do here, new m/c?, new lines?, high temp fluid? other things to look for?
Any help is greatly appreciated! I love this van and would love for it to brake consistently....
-Chris
-Chris
