by m1dadio Wed Nov 11, 2009 11:31 pm
Vanagain:
My TV cable is all factory on a TPI engine. I only diched the cruise control and changed the throtle cable.
BEFORE
AFTER
You can use your factory shifter as I did, with a cable. I used the old three speed linkage in the colum but it has no gate or lock out which makes it dangourous. I am looking for the auto colum for mine.
You can use your auto colum, you will need to modify it so it will provide the extra shift position for low 1. I think you just need to file it a bit. When you add the cable you need to get the levers right length to make it be in the right gear at the right time for the shifter.
Mine looks like this. Sorry this is the only picture I have.
There are quite a number of aftermarket kits to control these 700R4 with the TCC units. As I have been doing a pile of research to figure out my trany issuse I have discovered they are all very simple just not the same.
Probobly the best trany conversion kit for a stand alone 700R4 is the one were you have to remove the pan and re-configue the wireing inside the transmision.
I say this because you may buy a kit that adds a vacuum switch or a relay operated off a brake light wire or a dash togle switch but all of these work only if the inside of the trany is wiriered in the way that works with that kit. I have the GM manual for my set up. In it there are nine different wiring configurations, some ground the TCC solinoid inside the trany and some outside. Inside the trany There could be up to about four different presure switches and 3 temp switches that may, or may not, be in you 700R4 valve body and the TCC solinoid. I am told by one who knows that there is actiually 27 different combonations of these used with different wire layouts. Right from one that uses none, only the solinoid and one TCC possative wire coming out of the trany all the way to one that usses them all and has four wires coming out, and everthing othe combo in between.
So I don't see how just adding an external kit can possibly work for all 700R4 transmisions.
This is the problem with my factory set up shift problems. The only control my computer has over the trany is to turn the TCC on or off by switching the ground wire open or closed. But the donner car engine computer set up is 1988 and it had a 1992 trany installed at some point which has the wrong internal wiring / switches. All I have to do is pull the pan and change the wiring to what its suposed to be and possibly add or subtrach some switches, Easy to do You just need to know what to change it too.
