    A110 - Identity Solved
    A110 - Identity Solved Empty A110 - Identity Solved
    Post by Guest Sat Jul 06, 2013 11:25 am
    I have a Lazy Daze camper mounted on a 1968 Dodge pickup. We always thought it was an A100; Its NOT. The VIN plate says A110.
    When we tried to get new front brake drums, they could not cross reference the proper size. Here's why: Dodge made a heavy duty version of the compact truck series, both 90"-wb and 108"-wb.
    This heavy duty version is mentioned in the 1968 sales brochure for the 90"-wb body as: "5,200 GVW package". By reading through all the footnotes and fine print, I found what the package included. The link below charts the differences:
    https://i.servimg.com/u/f33/18/34/35/63/a110_v10.jpg
    For VVs with what identifies as A120, you may find the same HD upgrades take the standard 4000 lb version A108 up to a HD 5400 lb version A120.
    RodStRace: Thanks for you encouragement to get this figured out.
    Number of posts : 8735
    A110 - Identity Solved Empty Re: A110 - Identity Solved
    Post by dix Sat Jul 06, 2013 11:34 am
    Thanks for posting this . It's news to me.
    Post by dix Sat Jul 06, 2013 11:35 am
    Is there a 2nd vin type plate on the dash board closest to the drivers door ????
    Post by Guest Sat Jul 06, 2013 12:23 pm
    Since I'm in Tampa Bay, FL and the A110 is in Pueblo, CO with my son the mechanic, I can't answer immediately. I'll ask him to look when he has the shop open on Monday.
    Post by dix Sat Jul 06, 2013 12:59 pm
    The reason i asked is i've seen that plate at that location and never knew what is was...
    Post by Guest Sat Jul 06, 2013 2:23 pm
    Do you recall its contents - did the data on it duplicate the one in the door frame by the drivers left butt? Was it on a Dodge or a Fargo?
    Approximately what size does my son look for? Was it atop the dash or on the end where a closed door covered it?
    Post by dix Sat Jul 06, 2013 2:36 pm
    I've only seen it in photo's it may have been goverment but the owner said he bought it new, can't find the photo thou.
    Number of posts : 3046
    Post by RodStRace Sun Jul 07, 2013 9:25 am
    The government LOVES to add extra tags. Military, forestry/fire service, even old mail trucks got 'em.
    Clarendon, glad you got it figured out and shared it.
    Post by Guest Fri Jul 12, 2013 4:42 pm
    Sorry it took do long to reply. There are NO other stickers or plates on the dashboard.
      Current date/time is Tue May 28, 2024 8:27 pm
