+7
Bluelemon
Old Skool
Slowride
OldSkoolVannin
11 posters
    Still having shift problems Help!!!
    Still having shift problems Help!!! Empty Still having shift problems Help!!!
    Post by Guest Mon Dec 19, 2011 4:43 pm
    Hi
    My 63 E van would only shift to into 2cd and 3 rd now only 1st and reverse?
    Had the linkage, clutch, and trans. checked ok.
    It's the bushings in the column? Are there parts still available?
    I have taken it to three people one would not touch it, 2nd wanted $1000.00 to replace the bushings in the column(Leon's Transmission Costa Mesa,CA what a joke!) Third was not sure about the parts? Old skool emailed me but no price or where to contact him. So if anyone could help me it would be greatly appreciated.
    Thanks Rally72
    Still having shift problems Help!!! Empty Re: Still having shift problems Help!!!
    Post by Vanish Mon Dec 19, 2011 4:59 pm
    I Would PM .. VIC .. (Old skool) He can get it all straitened out !!!!
    Post by donivan65 Mon Dec 19, 2011 5:06 pm
    Vic thinks a whole lot better if you send him email at vlafountaine@socal.rr.com,
    Post by donivan65 Mon Dec 19, 2011 6:29 pm
    Will your van pass the Phillips Test?
    Still having shift problems Help!!! Philli10
    Still having shift problems Help!!! Pillip10
    Post by Guest Mon Dec 19, 2011 7:57 pm
    Yes
    Post by donivan65 Mon Dec 19, 2011 9:54 pm
    Can you shift into all the gears without starting the engine? Can you shift the transmission levers on the side of the transmission with the engine off if you take the rods off them. If you take off the rod from the 2nd and 3rd speed trans lever,,,,can you get the shift lever to move the 2nd and 3rd speed lever at the bottom of the steering column?
    Post by donivan65 Mon Dec 19, 2011 10:26 pm
    The shift tube has to move up and down when you lift up on the shift lever,,,,,if it does not, try squirting WD 40 on it where it goes through the floor,,,,
    Still having shift problems Help!!! Shiftt10
    OldSkoolVannin
    OldSkoolVannin
    Number of posts : 51
    Registration date : 2011-11-19
    Post by OldSkoolVannin Tue Dec 20, 2011 4:27 am
    Wow, glad to see this post. I am having similar but not the exact same difficulty. The trany and long linkage arms are fine, I can shift into all the gears with concentration and "finesse" but the up and down motion has severely been compromised because the cross over pin bushing is shot, probably about 1/8th of an inch shorter than it should be. I am also a little concerned about the sloppiness in the slots in the linkage arms @ the bottom of the shifter tube because they have enlarged. I have not been able to find the parts. I am going to take the Truck off the road to pull the carb, head and manifold, resurface the steering wheel, etc. so I'm planning to disassemble the shifter tube to rebuild it at that time. I saw a suggestion of building up some weld on the "key" @ the bottom of the tube and machine them back to matching sizes in the slots. I think I can "fabricate" a cross over pin bushing from some kind of pipe, sleeve or other suitable material I can find. Any suggestions to help would be appreciated, should I email Vic as well?
    Post by donivan65 Tue Dec 20, 2011 10:12 am
    If the grease is worn out or hardened up, that would gum up the shift lever movement,,,,so by spraying WD 40 all over and in, would help that problem,,,,so it's something to try,,,,,but if it's all worn out, it needs to be replaced. I think Vic needs to jump in right about now,,,,,,,,
    Post by donivan65 Tue Dec 20, 2011 11:31 am
    Here is an old Vic post,,,,,,,
    There is no factory bushing at the bottom of the column, the SUPPORT bracket that bolt up on the bottom is only for vertical support, the only bushing that is in the column from the factory is a plastic one in the aluminum mounting bracket.
    The only greasable zirc fitting there is,, is on the upper shift arm itself.
    I turn the end of the shift tube down, re-weld in brass, and then re-cut it to .750. Then I bore out the aluminum mounting bracket for more clearance, and install a bronze bushing cut down in the lower support bracket. Also, a MAJOR problem with the column is the shift pin, it is hardened and the shaft is not. You should be able to put in a 1/4" Phillips head screwdriver into the alignment hole and in both of the two matching alignment holes in the shifters. If you can then move the shifter back and forward more than a 1/2",, that indicates the hole in the shift tube is worn out. To fix that, get a 17/64th cobalt drill bit and carefully drill out the worn out 1/4" hole. Then make a new shift pin out of the shank of the drill bit to match the original length. That usually helps the slop situation there.
    Here are some pics showing a rebuilt 4spd, 3spd,and the alignment points so you can properly adjust your transmission shifters in neutral.
    vic
    Post by donivan65 Tue Dec 20, 2011 11:47 am
    Still having shift problems Help!!! Lev11
    OldSkoolVannin
    OldSkoolVannin
    Post by OldSkoolVannin Tue Dec 20, 2011 12:05 pm
    Wow, best picture so far thanks. So if my only problem is that cross over pin, the 17/64ths drill bit remedy will solve that. I still need to get the crossover pin bushing back to shape which I now think is my biggest problem. I emailed "Vic" and hope to get the words of wisdom that will put this all in perspective and get me passed this issue (& on to the next one).
    Number of posts : 3046
    Post by RodStRace Tue Dec 20, 2011 12:25 pm
    I hate doing many small repairs to the same components.
    It increases the possibility that something will get lost, broken or damaged. I prefer to get all the info and take it all apart once, fix it all to as new or better and reassemble/adjust.
    If you are going to pull all this apart, figure on fixing the crossover pin, the shift arm holes, the bushings, the ends of the rods and cleaning all of it and lubricating properly. Get any new parts (bushings, washers, zerk fitting, clips) needed before taking it all apart.
    Then you can concentrate on the other end by the trans. Once all of that is done, you should have a good tight, smooth linkage.
    Slowride
    Number of posts : 67
    Registration date : 2009-02-17
    Post by Slowride Tue Dec 20, 2011 2:25 pm
    I completely disassembled the column assy to clean and re-lube it. The biggest problem was dried grease which created too much friction to allow the lever pivot to move up and down smoothly. A little time, a lot of patience (and carb clean) and it works better than new with no hard part replacement required. Clean (or replace) the zirk fittings as long as you have it apart to ensure easy greasing later.
    OldSkoolVannin
    OldSkoolVannin
    Post by OldSkoolVannin Tue Dec 20, 2011 2:54 pm
    OK, all sounds logical. I have free unrestricted movement, so I do not see it being a dried grease condition. I like the idea of ".....no new parts needed" and allot of Carb Cleaner will do the trick. I want to ask, if you look at the swagged edge of the cross-over pin sleeve (opposite the cut out for the zirk fitting) in the picture in the previous post, mine is completely gone, the sleeve has lost about 3/16" of length and the edge is wragged and uneven. I cant believe this does not need replacement, and that a cylindical shaped metal tube with the close I.D. and a O.D. wouldnt be an adequate replacement. I think I am hearing no one has ever had to replace this part? I think the tube, linkage arms and bracket are fine. I believe I will have to replace the cross-over pin itself and the sleeve.
    Post by donivan65 Tue Dec 20, 2011 3:29 pm
    You try the simple stuff 1st,,,,,then it depends on the vans condition,,,,,I would say there must of been a lot of worn out Ford shifters for Vic to start making parts,,,,,,so lets wait and see what his take is on your questions,,,,,,
    OldSkoolVannin
    OldSkoolVannin
    Post by OldSkoolVannin Tue Dec 20, 2011 4:23 pm
    Yup, in email communication with Vic now, thank you..........
    Old Skool
    Number of posts : 1306
    Post by Old Skool Tue Dec 20, 2011 6:15 pm
    The shift tube is mild steel, the pin and the shift arms are hardened, so,, the shift tube hole wears out.
    This allows the pin to end up in different positions, no matter how many times you adjust the shifters. It needs to go up and down into each of the two column shifters without hitting the other one, the slop in the shift tube does not allow it to repeat itself and shift correctly without locking up.... SO, that is the FIRST thing to be addressed.
    On top of that, the lower z bracket (support bracket) IS NOT INTENDED TO CONTROL ANY SIDE movement, its ONLY FOR VERTICAL SUPPORT,,,,and the upper plastic bushing always gets worn out or stuck!!!! SO,, I make a replacement lower support in my rebuilt columns that uses a bronze bushing that I adapt to ours. Also, I cut the end down, braze it up, and then re cut it to fit the bushing with no slop. Ending up with brass against bronze,,, lasts for ever..
    Also, the NEXT spot is the upper support/fulcrum, ours are weak and I replace them with a GENII unit as it is much stronger. The came in the GENII's,, HOWEVER, 99% of them are automatics,,, sorry....
    Get all that slop out, and you will be able to adjust it and get a consistent up and down for neutral and not lock it up,,,
    vic
    BTW,,, THANK YOU GUYS FOR KEEPING MY POSTS AND THE PICTURES,,,,,
    MERRY CHRISTMAS TO EVERYONE....
    Still having shift problems Help!!! 000_0518
    Still having shift problems Help!!! 100_1214
    Still having shift problems Help!!! 100_1013
    Still having shift problems Help!!! 100_0913
    Still having shift problems Help!!! Empty SHIFT TUBE SLEEVE
    Post by Guest Sat Mar 02, 2013 5:40 pm
    BETWEEN THE SHIFT TUBE AND SHIFT TUBE BRACKET THERE IS A NYLON/PLASTIC SLEEVE. IS THIS PART AVAILABLE ANYWHERE?
    Bluelemon
    Bluelemon
    Number of posts : 139
    Registration date : 2008-07-10
    Post by Bluelemon Sun Mar 03, 2013 11:21 am
    Rally72 wrote:Hi
    Thanks Rally72
    Did You try adding bushings to the shift rods where they pass thru a crossmember/bulkhead under the driver's seat area ? The weight of the long rods will cause then to drag and bind.
    Old Skool
    Post by Old Skool Thu Mar 28, 2013 9:52 pm
    Hey guys!!!!!!! I am back kinda sorta,, still busted up pretty badly from the crash and work is very hard for me to do very fast,, but,,,, IT SURE IS NICE TO SEE MY PICS,, LOL...
    anyways,,, I would offer to fix his right now, but still catching up,,, feel free to call if you must, but please early am or late as it is really aggravating to get in and out of trucks all day to answer it,, sorry,,,
    Old Skool,,, aka,,,,vic
    Old Skool
    Post by Old Skool Fri Mar 29, 2013 7:54 am
    Call me,,,,,, I will go through it with you,,,,, the shift arm slots are hardened, but I have BOXES of them and I understand these shifters from top to bottom. Just please dont make me crawl out from under a truck,,it hurts
    Old Skool,,,,818-335-3033
    delraydoug
    delraydoug
    Number of posts : 210
    Post by delraydoug Fri Mar 29, 2013 11:22 am
    good information . did not know about putting screw driver in from the top to adjust rods. been doing it from the bottom not much room to work with.
    Still having shift problems Help!!! Empty problem solved
    Post by Guest Sat Mar 30, 2013 2:12 am
    i found a used column on craigslist that must of had 10,000 miles on it at the most. i cleaned it up put new rubber gromets with brass sleeves on the arms and it works like butter, couldn't be more pleased. thanx for all of your suggestions, also put a new rubber on the shifter itself.i'm no expert but my repairs make me feel like one lol!
    mik
    mik
    Number of posts : 64
    Registration date : 2012-04-14
    Post by mik Tue Mar 17, 2015 10:27 am
    Got the 63 started to get the cobwebs off but now I have this exact issue, stuck in Reverse and 1st. Tried the wd40 and carb clean etc but still will not budge. Looks like I may have to take apart, but thinking I should replace the parts while I'm at it...
    Vic you still selling rebuild shift assemblies?
    Don, you holding any Ford parts?
      Current date/time is Mon May 13, 2024 1:15 am
