    still got VR problems I think???
    still got VR problems I think??? Empty still got VR problems I think???
    Post by Guest Sat Feb 20, 2010 11:20 pm
    We got a new alternator and still have the problem: While the van is running we take the positive battery terminal off to see if the motor will keep running with out the battery, and it does not. I have been trying to find out if the VR needs to be grounded, or is it grounded through the 4 wires comming out of it?
    BN
    Seattle
    still got VR problems I think??? Empty Re: still got VR problems I think???
    Post by donivan65 Sun Feb 21, 2010 12:16 am
    Your last post says everything is OK,,,,,so is there a problem or not?
    ,,,and anyways,,,,,the regulator grounds through its base to the doghouse bracket,,,,,there should be a wire there or a clip,,,,,,the 4 wires on the regulator are all hot wires,,,,,
    Number of posts : 1383
    Post by chester42 Sun Feb 21, 2010 5:17 am
    If he alternator is working, it will be magnetized at the raer bearing housing. I was always told not to disconect the battery when motor was runnning as the alt. will run wild and burn its diodes out? pale
    Post by Digz Sun Feb 21, 2010 5:40 am
    I would like to suggest checking the wires around the horn relay, all the 12 volt feed comes up from the starter to that point to be distributed doesn't it?? The coil is fed while it is running from the small starter connection but that is being fed from above by the Alt. when the bat. is disconnected.
    still got VR problems I think??? Empty VR Problems
    Post by Guest Sun Feb 21, 2010 10:34 am
    Well I thought we had it- Ill check the grounding on the dog house- thanks - Im kinda slow when it comes to working on cars. but thanks for the help.
    BN
    Post by donivan65 Sun Feb 21, 2010 1:04 pm
    still got VR problems I think??? Chargi10
      Current date/time is Sun May 19, 2024 7:35 am
