    leaf spring questions
    leaf spring questions Empty leaf spring questions
    Post by Guest Thu Jul 04, 2013 5:52 pm
    The springs in the front of my 63 van don't match from side to side (One has more leafs in it)
    Also the front suspension beats and bangs on bumps rather violently. How many leafs should the springs have in them? and what should the stock arch on the springs be?
    Number of posts : 648
    leaf spring questions Empty Re: leaf spring questions
    Post by Rayallen Sat Jul 06, 2013 3:22 pm
    Factory they should be the same, but I have heard of people adding a leaf if one side starts to sag. If i had to guess its your drivers side that has more leafs.
    Number of posts : 726
    Registration date : 2012-09-26
    Post by NoBiggie Mon Jul 08, 2013 5:20 pm
    5 leafs standard van, 6 or 7 heavy duty. I just went through all of this and put all new leaf springs front and back. Mine had 6 or 7 and a few pieces. Over the years, guys try and balance them out and jury rig it because they get weak.
    I put in new leaf springs, new shocks, king pins, tie rod ends, just about everything. Rides like a dream. Just need to get the doors to stop rattling.
    66 E100
    66 E100
    Number of posts : 32
    Registration date : 2013-07-08
    Post by 66 E100 Tue Jul 09, 2013 7:53 am
    NoBiggie wrote:5 leafs standard van, 6 or 7 heavy duty. I just went through all of this and put all new leaf springs front and back. Mine had 6 or 7 and a few pieces. Over the years, guys try and balance them out and jury rig it because they get weak.
    Where did you get your new leaf springs? Custom made, or off the shelf?
    iambeninla
    iambeninla
    Number of posts : 60
    Registration date : 2012-12-02
    leaf spring questions Empty New leaf springs
    Post by iambeninla Tue Jul 09, 2013 3:48 pm
    My new leaf springs came from Eaton springs.
    66 E100
    66 E100
    Post by 66 E100 Tue Jul 09, 2013 6:48 pm
    iambeninla wrote:My new leaf springs came from Eaton springs.
    Do they make them specifically for the Econoline, or did you have to send them specs?
    iambeninla
    iambeninla
    Post by iambeninla Tue Jul 09, 2013 8:07 pm
    Yes they are specifically for Econolines.
    66 E100
    66 E100
    Post by 66 E100 Wed Jul 10, 2013 4:27 am
    iambeninla wrote:Yes they are specifically for Econolines.
    Awesome, thanks.
    Post by Guest Wed Jul 10, 2013 5:43 pm
    thanks. that is some great info. how much did a pair of front springs cost?
    iambeninla
    iambeninla
    Post by iambeninla Wed Jul 10, 2013 7:39 pm
    I bought the truck and they were already on there. Eaton Spring's number is 313-963-3839. Mine was sitting a little high so I had the springs dearched 2". Tell them what motor you are running that should get you the correct springs.
    Post by NoBiggie Thu Jul 11, 2013 2:17 am
    Eaton Springs for me also. They know what you need. The only issue I had on mine was on the rear springs. The new bushing they put in for the front end of the rear spring is about 1/8" too wide, and it is metal. So I had to grind them down on the grinder to get them to fit into the pocket that is built into the frame of the van.
    I had the normal spring in the front, and added 1" of arc in the rear to get some 'rake' to the van. That and larger rear tires gave me about 2" of rake.
      Current date/time is Sat May 11, 2024 9:31 pm
