    Leaf spring re-location
    a66dave
    a66dave
    Number of posts : 67
    Registration date : 2008-09-19
    Leaf spring re-location Empty Leaf spring re-location
    Post by a66dave Thu Jun 27, 2013 11:16 am
    Looking for comments and personal experiences from anyone who has done this.  I have a 66 A100 panel van, which the previous owner had mini tubed and performed a leaf spring re-location ( running along the frame rails ) . He ran it with a 440 and a 7 1/4 rear end to allow for big tires. When I purchased it had been returned to a stock configuration. I would like to once again re-locate the leaf springs to allow for bigger tires. My concern is vehicle stability with the springs in so tight. I could see this on a pickup, but was concerned with it done on a van. Not looking to run slaloms, but don't want a ton of body roll either. The move puts the springs inboard by 6 inches on each side.
    A100 Wrench
    A100 Wrench
    Number of posts : 572
    Leaf spring re-location Empty relocatation
    Post by A100 Wrench Thu Jun 27, 2013 12:50 pm
    The stability would be made up with tire width.Also the tires are still in stock location relative to the axis and center of gravity.
    Number of posts : 3046
    Leaf spring re-location Empty Re: Leaf spring re-location
    Post by RodStRace Thu Jun 27, 2013 3:00 pm
    Yeah, I don't see an issue with it, but if your real world testing shows an issue, you can always add a rear anti-roll bar.
    Stoopid john
    Stoopid john
    Number of posts : 265
    Post by Stoopid john Fri Jun 28, 2013 5:04 pm
    Moving the springs in does change the amount of body roll. Back in the day i had a ChevyII that i did that to. It's not real bad but it's a change. But i would think any type of sway bar would be a big help.
    Gusser
    Gusser
    Number of posts : 7
    Registration date : 2012-01-28
    Post by Gusser Fri Jun 28, 2013 7:51 pm
    Ive done suspension work on a few with that kinda mods and a good sway bar took care of the problem
      Current date/time is Fri May 17, 2024 8:37 am
