hey guys i have a 1966 chevy van and 3 on the column it gets stuck in 3rd gear and sometimes in 2nd how do i get this promblem solved?
stuck in 3rd
stuck in 3rd
- Number of posts : 8732
Re: stuck in 3rd
either the linkage arms comming off the trans are lose (tighten up ) or the bushings that the linkage rods go thro are worn out giving to much sloppy movment (replace bushings)
3 rd
how hard is that too do and where do you get the bushings?
Re: stuck in 3rd
I'm not sure if the 1st Gens are the same as the 2nd Gens, but here is a thread on this subject. If it's not the same, I'm sure Donivan will jump in and will probably have photos as well.
https://vintage-vans.forumotion.com/t29755-is-this-a-complete-shifter-setup?highlight=shifter
3rd
thanks man so much is this for a 66 chevy van?
Re: stuck in 3rd
I think the thread is for a 2nd Gen which started in 67 so hopefully Donivan65 can jump in and tell you if the shifters are the same or not. Best way is to take a look at what is on yours and maybe take a picture or two and post them so the gurus on here can confirm what you will need.
Re: stuck in 3rd
Great hope this will get it done ,thanks
stuck in 3rd
how did you get it out of 1st?
