jdlaugh
    Loose nut rant
    jdlaugh
    jdlaugh
    Number of posts : 298
    Loose nut rant  Empty Loose nut rant
    Post by jdlaugh Wed Mar 27, 2013 6:38 pm
    I've never work on this old a Ford, but I wonder if they understood the concept of captive nuts back in 1965? I just started taking apart the dog box around the engine -- looks easy enough, you can see the nuts holding the box down. Noooo. They are all bolts going down to free-spinning nuts under the floorboard. Wrench required above and below the floor. Up down up down up down. Not easy for a guy who works alone and just had knee surgery. Grrrr. What a Pain in the... knees. Rolling Eyes
    End of rant. Time for a relaxing beverage.....
    Number of posts : 1422
    Loose nut rant  Empty Re: Loose nut rant
    Post by Magic Bus Wed Mar 27, 2013 6:40 pm
    Its times like these when it sure is nice to have a buddy around...
    Number of posts : 2198
    Post by EconoUSAparts Wed Mar 27, 2013 7:43 pm
    From the factory there arent nuts on the bolts underneath,just a nutplate type thing called a cage nut. Sometimes those dont hold and you need to hold em with a vise grip. Its always good to have a 2nd person around. I just pulled a couple dog houses myself last weekend so I know what you're going thru but I had a buddy helping e.
    Number of posts : 252
    Registration date : 2013-02-02
    Post by campin'fool 2 Wed Mar 27, 2013 8:25 pm
    Once you get the dog house off you can reach the bottom bolts just fine.... drunken
    But yeah, more than a few of my friends, who are (were) not car guys that I call for help from time to time, are getting pretty good at it.
    I know where your comeing from.
    Good luck with your project.
    Joel
    Post by Guest Thu Mar 28, 2013 1:43 pm
    spot weld?
    jdlaugh
    jdlaugh
    Post by jdlaugh Thu Mar 28, 2013 1:49 pm
    I will be very tempted to spot weld those suckers when I put it back together. Not something I want to repeat anytime soon.... Evil or Very Mad
    Post by Guest Thu Mar 28, 2013 5:13 pm
    I've used vice grips in the past. Clamp it tight and try to get it to bind on another part of the body so it doesn't spin.
    Number of posts : 2011
    Post by Barnabas Thu Mar 28, 2013 6:13 pm
    Get yourself several pairs of vice-grips. Go under the van and grip several of the nuts, then go back up top to loosen them. That might save a little time.
    Old Skool
    Number of posts : 1306
    Post by Old Skool Thu Mar 28, 2013 8:57 pm
    I have two places that I buy them in bulk for all the jobs here. One I bumped into sells them by the lb. The easier one for all of you would be as simple as Mc Master Carr. They come a dozen or so to a bag, and come in three gauge metal sizes. Get the smallest gauge ones. TRICK!!!!!!!!! I use 1/4" thick nasty washers, and run a bolt down through the cage nut before I install the doghouse. Running the bolt down smashes them so that they hold easier. ANOTHER trick is a 5/8 open end wrench with someone underneath holding the square part while someone topside nails it with an impact.
    Old Skool,,,,,, back and lurking,,,LOL
      Current date/time is Thu May 16, 2024 11:58 pm
