I have the doghouse out and want to replace all the gasket. Google only found Herb's Parts sold off the spool at $4.00 per foot. Is there a better option?http://www.herbsparts.com/products.asp?cat=276&pg=4
A100 Doghouse Gasket
Re: A100 Doghouse Gasket
I used soft-seal when I did mine. I just compared what they had in the misc section and picked the closest one. Turmed out good.
- Number of posts : 8729
here is what 69a100 found something to use. http://www.soffseal.com/store/main.aspx?p=PictureListBody&c=UNEX
Sorry 69A100. When you wrote, you did not capitalize or otherwise indicate that "soft-seal" was the name of a company. It was only after I read DIXx reply that I understood yours.
Thanks, see my reply here. https://vintage-vans.forumotion.com/t18016-doghouse-lid-seal
I think we've got the doghouse lid gasket covered. What do we use for the seal between the various parts of the doghouse and between the doghouse and the floor?
What other gap around the house? For the floor you can either use strips of that foil covered bubble wrap that lines the house or use that thin width foam type weatherstrip thats about 1/4" thick.
Camper Tape Solution
On one of the Dodge A100 forum a question was asked about sealing the doghouse to the floor. A member responded "camper tape" which I didn't understand. He clarified with the following post.
It’s a foam tape with glue on one side that they put on a pick-up bed before they set a camper top on it. You can either stick it to the flanges of the dog box or the floor. If you get the wider stuff you can cut it in half.
