    Factory Number of Leaf Springs
    Number of posts : 726
    Registration date : 2012-09-26
    Factory Number of Leaf Springs Empty Factory Number of Leaf Springs
    Post by NoBiggie Fri Mar 22, 2013 11:50 am
    What were the standard leaf spring counts front and back for a 1967 Econoline? I am ordering new ones. Eatonsprings says the standard fronts are 5 leaf and the rear 5 or 6 leaf?
    Just double checking before 'springing' for them. Thanks!
    They should come with new bushings attached. So I will need new:
    Shackles
    Spring Clips (might be on them?)
    Spring Center Bolts (might be on them?)
    Ubolts
    This sound right?
    Number of posts : 8731
    Factory Number of Leaf Springs Empty Re: Factory Number of Leaf Springs
    Post by dix Fri Mar 22, 2013 2:07 pm
    center bolts and clips should be on them , the u bolts and shackles would be worth swaping out. easton spring should have it all,
      Current date/time is Fri May 17, 2024 9:42 pm
