    leaf spring bushings
    leaf spring bushings Empty leaf spring bushings
    Post by Guest Mon Jan 19, 2009 7:41 pm
    I've tried Napa, Autozone and Advanced but no one has them or they are obsolete parts.
    Anyone know a source?
    ID 9/16
    OD 1.1
    lip od 1.4
    length 1.5 inches
    similar to these leaf spring bushings Leafsp10
    thanks
    leaf spring bushings Empty SHACKLE/BUSHING KIT
    Post by Guest Tue Jan 20, 2009 2:34 pm
    TRY ROCK AUTO.COM ITS FULL OF HARD TO FIND PARTS. YOU LOOK UP YOUR VEHICLE APPLICATION AND IT GIVES YOU AVAILABLE PART NUMBERS THAT YOU CAN ORDER THROUGH THEM OR SEE IF YOUR LOCAL PARTS HOUSE CAN ORDER THEM. I GOT A SHACKLE KIT FROM THEM, IT IS A SPICER KIT#576-1013. IT COMES WITH FOUR BUSHINGS AND THE SHACKLE. CHECK OUT THE PICS. -GABE-[img]leaf spring bushings Shackl10[/img][img]leaf spring bushings Shackl11[/img]
    Post by Guest Wed Jan 21, 2009 6:18 am
    They have them in catologs from both www.Macsautoparts.com and dennis-carpenter.com if you go on these web sites they should have pics of them. I have also got parts from nation parts depot at their local store, but you can order thru them on line even though they dont sell econoline speciific parts I have found that some older tuck parts fit. They may also have a store buy you to take in for comparison.
    leaf spring bushings Empty Re: leaf spring bushings
    Post by Guest Wed Jan 21, 2009 5:15 pm
    Cool, thanks,
    I couldn't find that spicer kit, I've got a 1966 econoline.
    What year are these for?
    Post by Guest Wed Jan 21, 2009 5:52 pm
    ECONORAT- LOOK UP 1966 ECONO WITH 2.8/170 ENGINE. IT SHOWS AN ACDELCO KIT #45G13013 NOW. I BELIEVE THE BUSHINGS AND SHACKLES ARE THE SAME FOR ALL BUT THE SPRING RATES WERE DIFFERENT. -GABE-
    Post by Guest Wed Jan 21, 2009 6:12 pm
    Got it, thanks a bunch.
    Ugh, $75 ?!
    Post by Guest Wed Jan 21, 2009 6:34 pm
    YEAH, THEY WENT UP. I FOUND MY RECIEPT FROM FEB.08 AND I ONLY PAID 52.99 FOR THE SPICER KIT. I WOULD TRY TO SEE IF ONE OF YOUR LOCAL PARTS HOUSES CAN FIND THESE NUMBERS AND MAYBE GET A BETTER PRICE. IT'S WORTH A TRY. -GABE-
    Post by Guest Wed Jan 21, 2009 6:38 pm
    OH, BY THE WAY. YOU SHOULD GO THROUGH ALL OF THE CATEGORIES @ ROCKAUTO FOR YOUR APPLICATION AND PRINT OUT EVERY PAGE OF PARTS. THATS WHAT I DID. I HAVE A HUGE FOLDER OF PART #S FOR MINE JUST FOR FUTURE REFERENCE WHEN THEY DECIDE TO DELETE MORE #S FROM THE LISTS. -GABE-
    Post by Guest Sat Jun 06, 2009 1:24 pm
    the place i found spring shackle bushings and leaf spring bushings is stengel bros.inc.for a 1962 the part numberis hb533 8.00 a set of 4 and the leaf springs are about 8 or9 each hope this helps someone the number is 6104333149 i have somemore places for hard to get parts
    Number of posts : 2198
    Post by EconoUSAparts Sun Jun 07, 2009 7:07 pm
    Sean Odell at Blue Oval in California sells the eurethane bushing kits including the ones for the sway bar. He can be reached thru the oldeconolines website.
    Post by donivan65 Mon Jun 08, 2009 11:16 pm
    So how about this Napa bushing,,,,,,its close,,,,,maybe buy one and see if it can work?????
    leaf spring bushings Napa_b10
    Post by donivan65 Tue Jun 09, 2009 10:48 pm
    I think these may work for you,,,,,,,go to Napa and check it out......
    leaf spring bushings Bushin10
    Post by Guest Wed Jun 17, 2009 2:21 pm
    When i had the spring shop make all 4 of mine from scratch they had them on the shelf. if you have a place that makes them, stop in and ask. They should have them.
    Post by Guest Mon Jul 27, 2009 3:24 pm
    I would go with Sean O Dell. I got a bunch of bushings from his partner, Eugene Phillips before he passed away. They are very nice quality. I still have a box full stashed away somewhere in my garage.
    Post by Guest Thu Nov 12, 2009 12:43 pm
    Tried to locate Sean through the website you listed. No luck. Got a # where he can be reached.
    Number of posts : 1319
    Post by 67a 100 pickup Fri Nov 13, 2009 4:55 pm
    I got all my spring bushings and hangers from www.springsnthings.com they were easy to deal with and shipped really fast.
    Post by Guest Wed Mar 24, 2010 10:46 pm
    You can e-mail Sean at: shaggy069@earthlink.net .
    Hellfish
    Number of posts : 146
    Post by Hellfish Sun Jul 03, 2011 7:27 pm
    McVeigh's has the bushings, but not sure about the shackles. I got my shackles and bushings in a kit from RockAuto... cheaper than anywhere else. Mac's, Spicer, etc no longer carry the shackles. NAPA has them, but for a LOT more than RockAuto. Same kit!
    http://www.mcveighstrucksprings.com/
      Current date/time is Fri Apr 26, 2024 3:05 pm
