Is the '61 Master Cylinder different than other years? I was parts shopping on ebay and was only able to find a master cylinder for '62-up. Looks like Raybestos has a new replacement as well for '62-up. Any insight on this?
1961 Master Cylinder
Full Tilt Boogie- Number of posts : 44
Registration date : 2011-06-14
Re: 1961 Master Cylinder
61 is the same I have a new one in the box I can sell you cheap pm me
Big W- Number of posts : 3282
If your going to replace your master cyl which is a single, you should find one from a 67 (that is the only year for the dual master). with the original system !961 to 66, if you loose any of the 4 brake lines, you have no brakes. At least with the dual, you have the system split and you will still have front or rear brakes. Just something to think about for later on for a great and safe upgrade. You will also need the brake pedal assembly and brake push rod as well.
