    Has anyone seen this Master Cylinder adapter set up???
    Slick Steve
    Slick Steve
    Number of posts : 38
    Registration date : 2010-06-08
    Has anyone seen this Master Cylinder adapter set up???   Empty Has anyone seen this Master Cylinder adapter set up???
    Post by Slick Steve Sat Jul 03, 2010 7:51 am
    Econoline Master Cylinder Adapter
    Has anyone used one of these? I talked to the guy making these and it seems like a great option. Any ideas?
    Number of posts : 1747
    Has anyone seen this Master Cylinder adapter set up???   Empty Re: Has anyone seen this Master Cylinder adapter set up???
    Post by econopoor Sat Jul 03, 2010 8:40 am
    I've seen a few different versions of that style. That one looks better than most I've seen. The only problem I can see is that the push rod is very long. Has to be tuff so it doesn't bend when you push the pedal. There is a lot of force on it and lenght makes it worse.
    score602
    score602
    Number of posts : 140
    Registration date : 2010-04-05
    Post by score602 Tue Jul 06, 2010 4:34 pm
    i would use threaded rod with QA1 spherical rod ends...strength should be no issue with 7/16 or even 1/2 threaded rod
    score602
    score602
    Post by score602 Tue Jul 06, 2010 4:35 pm
    i know people said that a ford ranger master will work but what year are we talking??
      Current date/time is Sat May 11, 2024 2:46 pm
