Thermostat housing adapter plate 250 inline 6 cylinder
Post by Guest on Tue Jul 19, 2011 4:09 pm
Does anyone know where I could find a thermostat housing adapter plate for a 250 inline 6 ? On its trial run it blew a hole in the existing one and I am having no luck at all finding another. Parts stores carry the gaskets and the thermostats but not this part.
Re: Thermostat housing adapter plate 250 inline 6 cylinder
Post by Guest on Tue Jul 19, 2011 4:18 pm
Post by Guest on Tue Jul 19, 2011 4:57 pm
Did some searching online and came up with this ...
http://www.oehq.com/oeparts_ACD15-80766_ACD.htm#
Number of posts : 7732
Post by DanTheVanMan on Tue Jul 19, 2011 6:23 pm
Now I know a have a spare one of these....... TBS, I'll send you a PM with a pic tomorrow.....
Dan
Post by DanTheVanMan on Wed Jul 20, 2011 2:19 pm
TBS,
Have two extras.
Both Single side sending unit models. If interested send me a PM.
Dan
Post by Guest on Wed Jul 20, 2011 5:17 pm
Thanks Dan for looking but I have placed an order for the new part I posted, will definately give you a hollar if it does not do the job :c )
Number of posts : 911
Post by VANagain on Fri Jul 22, 2011 4:24 am
Good to know there is a source for brand new ones! I've heard they were very hard to find.
Dan, do you know what yours are out of? I like yours better than mine (and the new one) because the heater hose comes straight out. Mine points upward but in our vans the hose needs to go downward on its way to the heater core. I'm thinking mine will want to kink someday. I figure the straight ones are for our vans and the upwards one is for all other cars and trucks which have their heater cores higher.
Plus, I'd say our stock ones probably came with just the one hole for the sending unit (on 1st Gens anyway).
Post by DanTheVanMan on Fri Jul 22, 2011 4:58 am
Yep, All the one's I have came off of either a 230 or 250 and are all this type. the 230 in the Sportvan and the 250 from the Panel both still have this exact one.
Dan
Number of posts : 1487
Post by Scott on Fri Jul 22, 2011 6:30 am
I bought this one off eBay a while back. There are plenty out there, once you start looking you will find different configurations too.
Post by DanTheVanMan on Fri Jul 22, 2011 10:11 am
That's pretty cool Scott. Can't think of what to use 3 hole's for but that is very cooool!!
Dan
Post by Scott on Fri Jul 22, 2011 11:02 am
I put in a gauge thermostat along with the dummy light. I figure the light gets my attention more then the gauge. I just plugged the bottom one.
Post by DanTheVanMan on Fri Jul 22, 2011 11:06 am
Now that's a good idea!!!
cheers
Number of posts : 805
Post by jrinaman on Mon Jul 25, 2011 9:28 pm
would also be helpful if you use hot water to heat intake like required for headers.
jmon77
Number of posts : 19
Registration date : 2013-06-30
Post by jmon77 on Mon Oct 27, 2014 6:52 pm
I know this is an old post, but I am looking for one of the housing posted above. If anyone has a spare hit me up please!!! Thanks.
    Current date/time is Thu Apr 26, 2018 3:50 pm
