Hey all, I need help. When I close my passenger door, it pops back out about a half an inch. If I keep on slaming it, eventully it will stay closed. Is this a bad latch, poor adjustment of the latch, or what? When the door is shut, the body line matches good, so I believe the adjustment is good. Any help will be greatly apreciated. Dan.
door latch problem
door latch problem
- Number of posts : 8729
Re: door latch problem
it may need adjusted at the hindge, is the gap even on the hindge side?? have you used and spray pentrating oil in the door latch . It may help as well. open and close the door and watch for movment at the hindge. also open the door and look for anything rubbing.
